bsm removal
Old Nov 21, 2005 | 06:52 PM
maddman's Avatar
maddman
Default bsm removal
how hard is it to remove bsm is there clearcoat under it will it damage the paint what would you use to remove the residule addhesive
Old Nov 21, 2005 | 07:22 PM
MassaRusty's Avatar
MassaRusty
I just removed the BSMs off of a 1999 torch red hardtop with 100,000 miles. It turned out great. I used fishing line and a hair drier like others have suggested. Use good fishing line, mine kept breaking. Once they were off, I rolled off the big pieces with my thumb. I got a good blister from this. I used some bug and tar remover after that. I think it was turtle wax brand. Everything came off fine with no scratches. Everything is painted exactly the same underneath. After a good wax, you couldn't tell that they used to be there.
Old Nov 21, 2005 | 07:39 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
A heatgun may work better and faster.
Old Nov 21, 2005 | 07:43 PM
b98's Avatar
b98
too hot use hair dryer and dental floss.
Old Nov 21, 2005 | 09:01 PM
MyOwn69's Avatar
MyOwn69
I didn't even bother with the hair dryer after a while. I found the 30 lb. fishing line created enough friction that there was no problem.
Cleared off the "gummy" mess, a coat of finish, and one could NEVER tell!
Old Nov 21, 2005 | 09:02 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
heat gun and fishing line will work fine!
Old Nov 21, 2005 | 10:01 PM
g2103320's Avatar
g2103320
I used 25 lb line and just used a sawing motion to take the molding off. Hairdryer seemed to be of minimal help and I stopped using it after the first 2 feet of molding.
Old Nov 21, 2005 | 10:20 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I've thought about removing mine but I'm just not sure.
Old Nov 21, 2005 | 10:48 PM
BigPopaZ's Avatar
BigPopaZ
Old Nov 21, 2005 | 11:07 PM
I hear that something like Goof Off also works to clean off any residual adhesive.
Old Nov 22, 2005 | 01:08 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi maddman -
It is not difficult -
It will not harm the underlying paint -
Yes, there is clearcoat below the paint -
We used wd-40 as a lubricant for the fishing line - and this softened up the residual adhesive enough that it rubbed right off -
It helps to have a friend to gently pull the BSM away from the car while you do the fishing line work - just my experience.
best regards -
mqqn
Old Nov 22, 2005 | 02:12 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Originally Posted by mqqn
Hi maddman -
best regards -
mqqn
Key word: Gently.
Trust me.
Old Nov 22, 2005 | 07:27 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Same here. But you know what? If you remove them and either find you are not happy with the look or see any discoloration you can always get some 3M double sided tape and stick 'em back on. That is, as long as you don't destroy them getting them off. And I'm sure that can be avoided with some caution and a little patience during the removal process.
I'm looking at doing mine this weekend if I find the time.
Old Nov 22, 2005 | 08:06 AM
R3DC5's Avatar
R3DC5
I am wanting to do ours too. If I do, I'll try to get some pics.
Old Nov 22, 2005 | 08:28 AM
KMeloney's Avatar
KMeloney
What aren't you sure about?
Old Nov 22, 2005 | 01:01 PM
edensknight's Avatar
edensknight
To bsm removal
