DIC Battery volts
Old Nov 21, 2005 | 10:36 PM
Sillyme's Avatar
Sillyme
Default DIC Battery volts
What does your DIC say for battery volts when you turn on the key without starting the engine? I have a 04 thats a little over a year old. The battery has been sounding a little weak when I start it lately. Its not a daily driver and I have thrown a charger on it a few times lately, but my readout usually says: 11.7-11.8 volts. Is my battery maybe need to be replaced under warranty? Does GM just swap them out or prorate it towards a new one? From what I have read on the Forum, a lot of guys have had their battery replaced under the warranty. Thanks for your help.
Old Nov 21, 2005 | 10:38 PM
Goonie's Avatar
Goonie
my read out is bout 13.8 on average...
many on the forums have optima red tops
Old Nov 22, 2005 | 01:29 AM
Oldvetter's Avatar
Oldvetter
11.4 volts is a "dead battery", 12.9 volts is a fully charged battery. You should try to charge yours.
Old Nov 22, 2005 | 07:55 AM
cenzo's Avatar
cenzo
11.8 on my '04.
Old Nov 22, 2005 | 08:31 AM
C6~Missle's Avatar
C6~Missle
Your fine... mine is just under 12v
Old Nov 22, 2005 | 08:39 AM
Jim2003's Avatar
Jim2003
My 03 reads 11.7 or 11.8 when I turn the key on and not start it. When the engine is running it is 13.8 to 14.2 range. Both these numbers match my hand held volt meter. You are fine, you will not register 12. something without the engine running.
Old Nov 22, 2005 | 09:27 AM
mike348's Avatar
mike348
My 04 is 11.8
Old Nov 22, 2005 | 09:53 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Anything below 11.7 the battery should be replaced. At least have it tested before it takes out the alternator. My .02
To DIC Battery volts
