Door Lock Actuator Part Number?
Old Nov 23, 2005 | 06:08 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Default Door Lock Actuator Part Number?
The title pretty much says what I need.
My driver's door lock was on the fritz this past summer, working sometimes and not others. Now it is completely gone. Funny thing is, it is only when I try to unlock it that it doesn't work. Seems to work every time when I lock it.
And it's not my key FOB either. I have my doors set to unlock when I pull the key and it doesn't do it then either.
So, does anyone have the part number for a door lock actuator?
Thanks!
Old Nov 23, 2005 | 07:08 PM
kenrobb's Avatar
kenrobb
It is most likely the driver door control module that is causing the problem. Is a very common failure it seems. Do a search on this module and you will get a lot of posts. Part number 2775148 as we had to replace it on my son's 99 this summer. Got new one from Fred Bean's, $170 or so. Back in 02 part # was 9352881, listed for $222.36 then.
Old Nov 23, 2005 | 07:30 PM
Blindfingers's Avatar
Blindfingers
If you are adventurous there are ways to dress the contact points or replace the bad relay with one from Radio Shack.
Here are some possibilites
clean the contacts within the relays
http://forums.corvetteforum.com/show...dcm&forum_id=1
OR
replace the bad relay with a $3 part http://forums.corvetteforum.com/show...dcm&forum_id=1
Of course you can purchase a new DCM from your favorite Corvette purveyor.
Bob
Old Nov 23, 2005 | 11:52 PM
jaxgator's Avatar
jaxgator
St. Jude Donor '07
Thanks a lot guys!
Awesome tips there Bob. I'll look into those. Maybe I'll get out of this one cheap.
Thanks again.
To Door Lock Actuator Part Number?
