I just changed mine out about a month ago. I believe there is a pin that has to be pulled out, but really can't remember for sure. Just get a mirror and flashlight and you should be able to see the mechanism that way. Hope this helps.
It is not that hard, promise. If you can get under there you will see spring that goes over the pedal arm. This spring locks onto the pin that holds the pedal on.
Its faster to just remove the whole accelerator pedal assembley. Its two 13mm bolts and disconnecting sensor. This will give you much better look at pin.
Lucky guy, I just stayed stuck in the foot well sweeting my *** off until i figured it out by feel. took me a couple ours
I didn't have any trouble getting the pin out with the help of a screwdriver, but the spring went flying and it took a few choice words and a lot of contorting my body to get it back in. The result is
