Tiger Shark Kit
Old Nov 23, 2005 | 08:43 PM
nepafrankC5's Avatar
nepafrankC5
Default Tiger Shark Kit
I am on the fence with the tiger shark kit. I have an '01 sw z. The front cover is damaged and I have enough to purchase both pieces from the insurance check alone. But I am concerned about the brake ducts on the front. Can I retain these? And on the rear piece. Will it clear my borla stinger quad ovals? Wiring / lights - how involved is it?Any info will be helpful. Thanx.
Old Nov 23, 2005 | 09:25 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
the tigershark front fascia comes with new brake ducts.
go for it!
Old Nov 23, 2005 | 10:46 PM
edensknight's Avatar
edensknight
TheTigershark C5 body kit is one of the simplest and sharpest body mods around.
Old Nov 23, 2005 | 10:49 PM
MilleniumVette's Avatar
MilleniumVette
2024 C5 of the Year Finalist - Unmodified
I love the looks!! If you can swing it, go for it. Sounds like the ducting won't be an issue with the supplied kit.
Old Nov 24, 2005 | 07:03 AM
nepafrankC5
Great. That answers my first question. But if somebody can chime in if they know whether or not the borla ovals will clear the rear clip, that would be a big help. thanx
Old Nov 24, 2005 | 07:26 AM
slverc5's Avatar
slverc5
Not sure where I read it. But somebody was able to fit the stingers quads, but the mod meant cutting the quads into duals. But getting the duals alone won't help solve the problem as well. My suggestion is sell the Quad stingers and get the Corsa tigershark tips.
Old Nov 24, 2005 | 08:16 AM
RPOZ4Z's Avatar
RPOZ4Z
you may have an issue with the exhaust, a good idea would be to see if a forum member, that has the tigershark rear fascia, can measure the opening and compare that measurement to your exhaust.
the front fascia uses all of the factory lights and hardware.
it bolts on just like the factory fascia, fit and finish were flawless, mine just needed very minor prep before paint.
Old Nov 24, 2005 | 08:37 AM
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Your current exhaust would have to be modified. I had the regular 4 tip Corsa's and had to cut the outer 2 tips off to clear the TS rear. (These Corsa's are for sale if anyone is interested)
Here's some dimensions for you with the Corsa's on the car...
GHL's that I have now...
Old Nov 24, 2005 | 12:25 PM
nepafrankC5
Thank you very much for the measurements GB. I would rather mod the fascia a tiny bit. I will have to research the materials. Has anybody cut and mended this type of material b4? My other option is to go with the spectre works gtr rear fascia. But the spoiler lip is not as dramatic as the sharks........
Old Nov 24, 2005 | 12:27 PM
On the road's Avatar
On the road
Make sure you post pictures when it is done.
Old Nov 24, 2005 | 01:15 PM
RPOZ4Z's Avatar
RPOZ4Z
I would mod the exhaust before I messed with the rear fascia.
Old Nov 24, 2005 | 01:29 PM
Go for it. The Tiger Shark pieces are great.
Old Nov 26, 2005 | 10:09 AM
nepafrankC5
Ok. The tiger shark kit project is not going to happen. I just purchased the borla exhaust and I'm not about to hack it or replace it. Body mods were not on my list until it got hit. The tiger shark kit is beautiful. And I feel that the whole kit should be installed if one is going that route. If I had purchased the corsas I'd be ordering the kit. But I don't. So I am going back to oem look with Caravaggio wing and eventually the conards. Flush tail lights and the lower portion of the rear fascia blacked out. Like No Mercy's MTI Z07. Pics will be posted.
Frank
Old Nov 27, 2005 | 11:03 PM
CustomShop's Avatar
CustomShop
I have the tiger shark and when i order they said i had to use the corsa system it was deisgned for the baoy kit. but they did say you can modify the stock or you other ex. so I would say you should be able to use it but you will have to modify it. see my pics
Old Nov 27, 2005 | 11:19 PM
b98's Avatar
b98
I have the whole kit, had the borlas 4 tip would not work, tryed the 2 tip would not fit. Called GHL , worked with them to make something. They now have a 2 tip that works. You can cut the borla 2 tip to fit but it will not be easy to get the right fit. the GHLs are polished from one end to the other. looks & sound good.
Old Nov 28, 2005 | 01:55 AM
Dixit's Avatar
Dixit
GB Vette, Ive been dying for these measurements, thanks a bunch. Got one more request for you. Can you measure from the ground to the top of the tips? Just want to know how high the tips can be before it touches the underside of the tip opening.
Dixit
Old Nov 28, 2005 | 06:58 AM
GB Vette's Avatar
GB Vette
NCM Ambassador
Dixit
The ground up measurement is going to be different on just about every Vette you measure. It depends on a lot of things, lowered, wheels/tires, etc. The top of the exhaust opening on the TS rear is in the same place as the stock one because of attaching points.
Old Nov 28, 2005 | 09:45 AM
name2320's Avatar
name2320
Default GO With Tiger Shark
It cost me around 150 dollars to have a stock TI z06 Exhaust modified. The wiring harness is easy with a soldiering iron and some shrink wrap, the parts are inlcuded in the kit all you are doing is cutting one break light wire to allows the rest of the harness to move freely, all holes are predrilled so your stock hardware will work. I would go for it, it just looks good and sets your car apart from every other corvette out there.
Old Nov 28, 2005 | 09:46 AM
Dixit's Avatar
Dixit
Got it, thats all I needed then. Just wanted to make sure the top of the exhaust opening on the TigerShark wasnt lower than the Stock rear. Thanks for your help.
Dixit
To Tiger Shark Kit
