[Z06] Winter mods.. cam recommendations needed.
Old Nov 24, 2005 | 07:32 AM
blk05coupe's Avatar
blk05coupe
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Winter mods.. cam recommendations needed.
Winter is here so it’s time to plan for spring, I’m thinking of porting and polishing the heads and a new cam.
Big is good but I still want reliability and driveability, thoughts please.
thanks
HAPPY THANKSGIVING
Old Nov 24, 2005 | 07:40 AM
Geneus's Avatar
Geneus
The LG G5X3 cam on a 114 lsa seems to be a winning combo with the Z06, using the stock heads and stock intake/TB. Many here have gotten as much as 430+ rwhp/400 rwtq from this cam, and yet it retains excellent street driving characteristics.
The TREX cam is another good option, and Cartek also offers a choice with either their 2x or 3x cams. Lots to choose from, and they are all very good.
Old Nov 25, 2005 | 11:34 AM
zo6vetteman2003's Avatar
zo6vetteman2003
Hey Geneus,
Isn't that your cam selection??
Todd Griffith
Old Nov 25, 2005 | 04:53 PM
Geneus's Avatar
Geneus
Originally Posted by zo6vetteman2003
Hey Geneus,
Todd Griffith
Todd,
Yes...i have the G5X3 and have recommended it to many. However, there are a whole lot of choices, and one needs to decide what fits with ones current/future mods scheme. I have a friend who has the TREX cam and it was the right choice for him. Robz has the Cartek X3 cam, and noone will dispute how that has performed for him.
As I said...choice is a good thing.
Old Nov 25, 2005 | 07:53 PM
zo6vetteman2003
Todd,
Hey Geneus,
I thought maybe you did not recognize me as zo6vetteman2003 so:
http://www.corvetteactioncenter.com/...ad.php?t=75161
Yes, I agree on calling the cam help line.
Old Nov 25, 2005 | 08:05 PM
CYA-Vett's Avatar
CYA-Vett
Too Big
Old Nov 25, 2005 | 09:53 PM
Geneus's Avatar
Geneus
Hey Geneus,
Sorry about that, Todd. I think its old age creeping up on me...LOL.
BTW, noone should listen to CYA-Vett...Dave wants to sell his Z and buy a Rustang.
Old Nov 26, 2005 | 06:41 AM
pb24dagrk's Avatar
pb24dagrk
This might seem like a silly question, but I have barely started looking into a Cam......
if I look into one of the ones you listed above, would I need to upgrade my springs/valves/lifters/rockers or ANYTHING?
I'm looking for a "cam only" type package.....how much should I expect to pay for a cam only? and about how much are labor costs these days for a cam?
This is my daily driver ('04 z06) and I have a few mods (headers, intake, catback, tune, 398rwhp) and not looking to do anything more after the cam (heads are out of my budget)......
Old Nov 26, 2005 | 07:25 AM
Geneus's Avatar
Geneus
I'm not sure what the costs would be if you have this done where you are, but around here a "cam only" package (with a big cam) would run somewhere around $2500-$2800, and that would include tuning. With this is included dual springs (Comp 921's are the best...and the most expensive), hardened pushrods, dual roller timing chain, porting of the oil pump, and typically a UD pulley. If you contact LG, he sells all of these components (with the exception of porting the oil pump) as a "turn key" kit if you are a DIY'er for his G5X3 cam...I thinks its ~ $1500. Remember that about $500 of that cost is for the springs...a very important aspect in a "big" cam install. I am told the stock rockers/lifters on the Z are more than sufficient.
Old Nov 26, 2005 | 08:08 AM
zo6vetteman2003
Hehe, they call it CRS lol. We all seem to get that from time to time.
Old Nov 26, 2005 | 08:20 AM
zo6vetteman2003
I installed my cam and valvetrain and saved quite a bit. There are miscellaneous expenses I ran into. The most important tool I had to buy was a good valvespring compressor. The best one that I have seen is the one that Crane offers. It's compact and does 2 valvesprings at once. The driver's side rear, near the firewall is the hardest for a right handed person. It is a good idea also to go with a double roller timing chain for insurance. These miscellaneous items do add up, but a piece of mind helps when you go WOT.
Old Nov 26, 2005 | 09:51 AM
CYA-Vett's Avatar
CYA-Vett
This is what we all say......And I bet at first, you said ONLY headers....Am I right???
What do you plan on doing with the car? Will you be racing it? If so go with the G5X3 cam (which is too big ), it is proven and very popular but if you are just going to drive around town and want your car to sound mean and get good power I'd go with the MTI X1, that cam isn't too big but sounds nasty (bigger) and unlike to G5X3, you will get power from idle to redline. The G5X3 will make more peak power but not until you hit the higher RPM's. I ran 11.5 with the X1 and made 417HP 407 torque, it will give you more torque too.
No matter what cam you get, you will need springs, pushrods, new gaskets/seals and its always a good idea to upgrade the timing chain too since the car will already be apart and replacing doesn't cost a thing, same goes for an underdrive pulley...
Old Nov 27, 2005 | 06:27 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
No matter what cam you get, you will need springs, pushrods, new gaskets/seals and its always a good idea to upgrade the timing chain too since the car will already be apart and replacing doesn't cost a thing, same goes for an underdrive pulley...[/QUOTE]
And get the comp 921 dual springs for sure as the few extra hundred is well worth it and i have never heard of this spring failing!!
ITs a no brainer, the G5X3 is a battle tested performer to be used on a stock headed LS6 motor and you will want to keep the lsa at 114 so you do not have to do any flycutting of the piston. Another great choice afe the Allan Futrual LSX grinds and in your case the FM11 or so would be great with specs similar to something like 232/234 on a 112 lsa a .590 lift, etc. Call ALLAN at FUTRAL MOTORSPROTS and let a rea expert point you in the right direction but can't go wrong with the G5X3!!
Old Nov 30, 2005 | 07:06 PM
Kens06's Avatar
Kens06
Here are stock lifters with an X2 and 921's after 12K!
The cam was just as bad!!
No one would take responsibility for the problem so I had to eat all costs!!
Just a heads up!!
Ken
Old Nov 30, 2005 | 08:55 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Well wtf caused that?
Old Dec 23, 2005 | 06:20 PM
wrath03Z06's Avatar
wrath03Z06
4th Gear
Default wrath03Z06
With all this chop , duration, and lsa wont you need to do gears somewhere to make up for the lost bottom end power on a bigger cam. re: something similar to an g5x4?
To Winter mods.. cam recommendations needed.
