Tc Or Gears
Old Nov 24, 2005 | 06:12 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Tc Or Gears
If someone can afford one or the other what would you do with an auto and 2.73 gears.Put in a high stall TC or change the gears and why.
Old Nov 24, 2005 | 06:59 PM
99 vett babycar's Avatar
99 vett babycar
if you can ONLY do one - do gears.
Old Nov 24, 2005 | 07:19 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
BUT.... I would not hesitate to do the TC only if the number$ were better... Can you not do both? I would think that the labor on both at the same time would be less than the two at different times given the work...
Old Nov 24, 2005 | 08:27 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If you can only do one, do the gears. The tc only helps at low rpm; the gears will help all the time.
Old Nov 24, 2005 | 09:15 PM
Steveo1c5's Avatar
Steveo1c5
Gears Gears Gears
Old Nov 24, 2005 | 09:30 PM
Dark-Knight's Avatar
Dark-Knight
Greatest bang for the buck are the gears, next question is which ones?
Old Nov 24, 2005 | 09:32 PM
azmusclecar's Avatar
azmusclecar
A T/C may involve installing a tranny cooler so keep that in mind. But you will need to get your car reprogrammed with the new gears unless you are going from 3:15 to 3:42's so there are costs involved both ways. Just something to think about when push comes to shove
Old Nov 24, 2005 | 09:37 PM
Jeffs FRC's Avatar
Jeffs FRC
Wow...im gonna have to eat it on this one!!! Can I ask some of you the gains you recieved from doing a gear swap only compared to those of you who have done a converter swap only? Track times only please, no SOTP. I'll start...2.73 car with a 3200 2.5 converter. Went from a 12.99@108 1.99 to a 12.47@108 1.77 with only changes being the converter, trans cooler, and a transgo shift kit. This was in a 99 z28.
Jeff
Old Nov 24, 2005 | 09:38 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
GEARS...BUUUUT save a little while longer, and since you're paying the same labor, go ahead and get both...i think it'll be worth the wait.
Chris
Old Nov 24, 2005 | 10:05 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Chris
Especially if you plan on doing the other in the next year or so.
Old Nov 24, 2005 | 10:28 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Do both at the same time - it will cost you twice because the labour is the same for gears or stall.
I went from 2.73:1 and stock TC to 3.90:1 and Yank SS3600 stall
Night and day difference. Love it.
Old Nov 25, 2005 | 07:46 AM
Gears would be best if you can only do one, but I agree that you may want to wait and do both at the same time.
Old Nov 25, 2005 | 08:03 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Since I was tearing it down anyway, I decided to go "all in". We did Yank 3600 converter, trans cooler, transgo shift kit, and 3.42 gears.
I also had some transmission tweaks using LS1-Edit....quicker shift points, higher red line rpm....
I run at 2400 RPM at 78 mph on the interstate. In my MN6's I run at 1800 at the same speed.
I would recommend though if you go higher than 3.42 that you research getting the hardened shafts too.
To Tc Or Gears
