Centering Steering Wheel
Old Nov 24, 2005 | 08:37 PM
Barry Hanna's Avatar
Barry Hanna
Default Centering Steering Wheel
Is this tough to do? I took the car into the dealer, told them it was about 10 degrees off center. The repair ticket said they adjusted the front and rear suspension, I never noticed anything wrong with the steering, the wheel is still off center. Is it a problem to center? Just curious.
Old Nov 24, 2005 | 08:41 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
I had this exact problem with a VW Jetta VR6 I had brand new. I didn't get it fixed for a few thousand miles and by the time I got around to it they told me they wouldn't fix it without charging me for an alignment!!! There wasn't an alignment problem, the steering wheel was crooked! Anyway, here's the deal:
It's not a big deal for them to center your steering wheel, BUT it WILL cause them to have to do a realignment after they are done simply because of the work they have to do to straighten it. It was just installed improperly.
Old Nov 24, 2005 | 09:01 PM
ericdwong's Avatar
ericdwong
Setting the alignment will center your steering wheel. They will adjust the toe settings on both wheels, one way at the same rate and it will center the steering wheel. I can't really explain it in words without showing with a model....
Old Nov 24, 2005 | 09:15 PM
Barry Hanna
Thanks, evidently what they did, didn't work. Guess I'll try again, not a big deal, but I just want it right. I'm probably too picky. I have a E320 M-B and they seem to fix things like this the first time, oh well, an SL would have been another $50k over the C5 so I suppose I'll just grin and bear it.
Old Nov 24, 2005 | 11:01 PM
corvette dave's Avatar
corvette dave
Barry,
Have the alignment tech drive the car or ride along with you for a test drive.
It is much easier that way.
Very easy fix.
Old Nov 24, 2005 | 11:19 PM
On the road's Avatar
On the road
Old Nov 24, 2005 | 11:21 PM
Shane_S's Avatar
Shane_S
I had a little indipendant shop guy allign my yukon and he centered the wheel for me. Just dont go to a firestone.
Shane
Old Nov 25, 2005 | 12:03 AM
gtzy's Avatar
gtzy
after loosening the outer tie rod nuts,the both inner tie rods can be equally rotated in opposite directions to move the steering wheel [right or left] without affecting the alignment.
Old Nov 25, 2005 | 12:24 AM
edensknight's Avatar
edensknight
Originally Posted by corvette dave
Barry,
Very easy fix.
Old Nov 27, 2005 | 02:36 AM
Cart99's Avatar
Cart99
This is not hard to fix -- just did it myself. But, you need to tell the alignment tech the problem.
Old Nov 27, 2005 | 03:31 AM
DaBeast's Avatar
DaBeast
how did u do it?
i need to do it as well
thanks
Old Nov 27, 2005 | 12:53 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The overall front toe can be correct, but the individual toe is hard to get correct on the front. The front tires will self center as the car rolls down the road due to the caster in the front spindles. To center your steering wheel without changing the overall toe, you need to shorten one front tie rod and lengthen the other by the same amount.
Short example:
Say your steering wheel is straight and your car turns left. You need to move both front tires to the right to result in a centered steering wheel. To do so, you would shorten the LF tie rod, and lengthen the RF tie rod by the same amount. 10 degrees of off center wheel is about two flats of the tie rods.
As a note, I have toe plates, so when I'm done doing this, I can check my total toe and make sure I didn't mess it up.
Best bet if you don't have toe plates, is to take it back, drive it with the alignment tech and let him do this for you. Good luck.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 27, 2005 | 03:59 PM
2KFRC5's Avatar
2KFRC5
http://www.hunter.com/pub/undercar/2470T/
Old Nov 28, 2005 | 03:33 AM
DaBeast's Avatar
DaBeast
so what is the best or easiest DIY way of aligning the steering wheel?
To Centering Steering Wheel
