Tire sensor core
Old Nov 24, 2005 | 09:55 PM
bowtiebubba's Avatar
bowtiebubba
Default Tire sensor core
Ive got one of my tire sensors valve core leaking.Tried to tighten it but still leaked.I thought i would try replacing the core,does the sensors take a normal valve core or does it need to be a special one for the sensor?
Thanks guys
Old Nov 25, 2005 | 06:36 AM
C4TOMCAT's Avatar
C4TOMCAT
I have just replaced with standard cores...keep the length of the original...found the stem bent slightly....make sure there is nothing stuck in the seat area..taking the core out will usually let the air in the tire clean the seat...I use a flashligh and Qtip to check seat. Hope this helps.
Old Nov 25, 2005 | 08:26 AM
bowtiebubba
Thanks C4tomcat i will give that a try today.
Old Nov 25, 2005 | 08:44 AM
nmbsun's Avatar
nmbsun
Thanks guys
It seems GM does want a special valve stem used in the sensor. It has a zinc coating to prevent rust. You can get it for $1.31 at Fred Beans . com. This is a sponsor dealer for Corvette Forum. The entire sensor is only like 30.00 dollars and it comes with the aluminum cap and valve. Below is the link to the valve stem. This sensor is for a 2001 to 2004 vette. The early vettes used a different sensor.
http://www.trademotion.com/partlocat...04&catalogid=2
Old Nov 27, 2005 | 02:29 AM
Cart99's Avatar
Cart99
could also be leaking around the valve stem. May want to check that for leaks. You can always get the new o-rings from the dealer, or the #9 orings from Home Depot. May be worth checking..
Old Nov 27, 2005 | 06:18 AM
StevieB's Avatar
StevieB
I have the C5 locking caps. If you over tighten, it will cause the tire to lose air. I think it's because of those little o rings pressing on the stem. We never have the problem in our family truckster that uses those plastic caps.
Old Nov 27, 2005 | 12:58 PM
bowtiebubba
I put in a new valve core yesterday and that solved the problem. I went to the local auto parts bought a box of 5 for 1.75 and worked fine.
Old Nov 27, 2005 | 01:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I had the fancy logo caps too. I couldn't understand why a couple of the tires kept loosing air. I finally discovered that the flat caps were just touching the top of the Schrader valve, and I was losing about 5 lbs per day. I found some cheapy domed caps that look like chrome and the problem disappeared!
Old Nov 27, 2005 | 03:44 PM
edensknight's Avatar
edensknight
Standard cores: No Problem. Also, be sure the o-ring in the valve stem cap itself is not deteriorated, or, damaged. Good luck to you.
To Tire sensor core
