Do all C5's need CLB?
Old Nov 25, 2005 | 08:26 AM
rc51racer's Avatar
rc51racer
Default Do all C5's need CLB?
I just bought my first C5 six speed in Sep. 05. I can here the motorized sound in the dash when I take the key out. Do I need to do the CLB or is it certain models or years? What about the dealer, is this covered on a recall or anything else? My 99 Corvette is out of warranty with 47,000m.
Old Nov 25, 2005 | 08:51 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Yes, you need a CLB. Normally, if a CLB has been installed, you don't hear the whinning sound when the ignition key goes in/out and you can turn your steering wheel when the key is out of the ignition. Do not take the car to the dealer. Install the CLB yourself....
Old Nov 25, 2005 | 08:58 AM
nmbsun's Avatar
nmbsun
This is a very debatable proplem with the C5 six speed. If the previous owner had the recall 'fix' done it could screw up the aftermarket CLB. The automatic vette owners have it lucky, they dont have to put up with this problem. The recall will completly take out the Column lock.
Do a search on column lock problems after the factory 'fix' and then installing a CLB. Good luck!
Old Nov 25, 2005 | 09:06 AM
EZEDDIE's Avatar
EZEDDIE
Install the CLB. Image the pain of seeing your vette being wenched onto a flatbed because your steering column lock failed to unlock. This can happen! There's a bunch of guys of this site that have told the sad story.
PS: I am about the further thing from a car mechanic. I did the install myself. It took me 3 hours since I REALLY took my time. Most of the time was just trying to figure out how to work in tight places under the dash. The actual install is easy. In other words, if the work area under the dash was 3 times it's current size, you could do the install in under a 1/2 hour.
TOPGUN9's Avatar
TOPGUN9
The CLB was the first mod I did on my '99 coupe when I bought it new because I didn't want to run the risk of getting stranded far away from home. Being that you can hear the whining sound of the column lock motor when you turn the key, I would guess your Vette doesn't have the CLB. Do a search, and I think you will end up installing the CLB.
Old Nov 25, 2005 | 09:57 AM
28tudor's Avatar
28tudor
Default Make me Nervous
The original owner of my MN6 2000 Conv. showed me the sticker under the hood where the Dealer did the "Factory Fix" Some say this is OK others say not...On this post, it seems dealer fix may interfere with CLB on a MN6. You know, since about 1973 EVERY car has to have a column lock per the Gov. How can something this simple be such a problem on a High Line car? Oh Well, I just wish I knew with certainty what to do...Meanwhile...a great, fun,car.
Old Nov 25, 2005 | 10:42 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
YES , install the CLB!!! Best mod on a C5!!
Old Nov 25, 2005 | 11:52 AM
rws.1's Avatar
rws.1
My '01 six speed had the dealer recall done twice and I was still getting the pull key 10 seconds and wiat problem along with once having the column lock....
Don't know what the dealer did or didn't do... But I got the CLB from Corvettes of Houston the next week and things have been perfect since then.
Old Nov 25, 2005 | 03:27 PM
GrandSportRob's Avatar
GrandSportRob
All 6spd C5's NEED the bypass...01 and up automatics have it disabled from the factory....
Old Nov 25, 2005 | 06:31 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Yeah, that's apparently correct. I've got an A4 '03, and you can turn the steering wheel without the key in the ignition ... it doesn't lock at all.
Old Nov 25, 2005 | 08:00 PM
BostonJoel's Avatar
BostonJoel
I bought and installed the CLB right after I bought the car and found this forum. For a non-mechanical guy like me, it took about 90-120 minutes start to finish. Best mod you'll do to that C5.!!!!
Old Nov 25, 2005 | 08:53 PM
Z0SLIK's Avatar
Z0SLIK
That's good to know!!
Old Nov 25, 2005 | 10:08 PM
zipduda's Avatar
zipduda
Very eeeezzzzz to do for under $50.00. It takes about 1/3 hr to do, follow the instructions they provied. Order one and install it yourself and never worry about the problem again. You'll laught at how worried you were to do this yourself after you installed this simple little plug!
Old Nov 25, 2005 | 10:14 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Been there, done that. Not much will **** you off more than having a nice vette that you paid for lock itself down when you have it parked away from home. And then having to pay $500+ to have it unlocked so you can drive it again.
The memory still pisses me off, that was on my '98 when the problem was generally denied by most people. The first mod I did to my '02 was a CLB.
Old Nov 26, 2005 | 08:59 AM
rc51racer's Avatar
rc51racer
Well it looks like I have to pay a mandatory $50 or so on a GM factory flaw. One would think GM would stand behind there CL failure. Do not get me wrong I think the Corvette is one of the best cars ever built for the money. I just can't help thinking in the back of my mind that it is still a Chevy. Does anyone have a link or brand name on the CLB product?
Old Nov 26, 2005 | 12:02 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Old Nov 26, 2005 | 12:05 PM
Dave1998's Avatar
Dave1998
I got mine from Thunder Racing. Forum vendor. Look for them on left side of this page. Easy Install.
To Do all C5's need CLB?
Old Nov 26, 2005 | 12:52 PM
rc51racer's Avatar
rc51racer
Thanks guys for the support. Looks like I will be doing the CLB asap.
Old Nov 26, 2005 | 01:56 PM
jrose7004's Avatar
jrose7004
There are only 2 kinds of C5's. Ones that have have the column lock problem and ones that will!
Old Nov 26, 2005 | 02:13 PM
gpotski's Avatar
gpotski
GM doesn't know either!
