I have a 9'8" ceiling in my garage and my C2 fits nicely above my C5 with room (not a lot) to spare. Most of the lift companies recommend a 10' minimum ceiling height.
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
I have 10' 1' clearance with my 4 post lift
with my vette on lift I can stand under car to work on it and I am 6ft tall and still have a few inches to spare
you should have no problem with clearance
They sure make life easier working on the vette
By the way, lots of threads about lifts on the forum right now.
The following three threads cover it pretty well... at least maybe you can narrow down the questions you may have this way?
I think something else that maybe was not covered in all of this info was the fact that when your door is up and the car is under it, the rear deck or the hood portion is lower than your roof area allowing PLENTY of clearance... Stacking two vettes with 11' 2" of clearance is easy!!
