Mystery Pouch - Help Needed
Old Nov 26, 2005 | 10:11 AM
Sportryder's Avatar
Sportryder
Default Mystery Pouch - Help Needed
What is in the little brown pouch zip-tied under the passenger seat of an '02 coupe? I'm looking for the CD changer hook-ups but can't remember if they are routed under the passenger seat of the C4's or C5's (or neither; the older I get, the smarter I was). Thanks for any clues.
Brett
Old Nov 26, 2005 | 10:43 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Not sure what's in the pouch, but the CD wiring is under the passenger side carpet on the outside edge of the seat, just forward of the door opening. Pull off the scuff plates and pull the carpet back to find the wiring harness. You'll see one set of wires not hooked to anything. Then pull off the footwell cover on the passenger side and the other connection will be below and to the right of the fuse block, most likely facing away from you on a little metal tab.
Old Nov 26, 2005 | 10:58 AM
toplessvettetherapy's Avatar
toplessvettetherapy
Does the POLICE know about your little ziplock BAGGIE!
Old Nov 26, 2005 | 11:04 AM
Speed Trap's Avatar
Speed Trap
Open it up and let us know what's inside. Could it be your wheel lock key?
Old Nov 26, 2005 | 02:33 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I think it holds the ticket to ***** Wonka's Chocalate Factory!
Old Nov 26, 2005 | 03:03 PM
shurite44's Avatar
shurite44
!!!Don't touch that squirrel's nuts!!!!!
Old Nov 26, 2005 | 03:59 PM
WWK888's Avatar
WWK888
Brett
Uhhhh...why not open it and look for yourself?
Old Nov 26, 2005 | 04:51 PM
rws.1's Avatar
rws.1
Is it ticking?
Old Nov 26, 2005 | 04:53 PM
Mike McCoy's Avatar
Mike McCoy
It contains the air pump for the seat bolsters.
Old Nov 26, 2005 | 05:01 PM
Mike Mercury's Avatar
Mike Mercury
it's called a "stash"
Old Nov 26, 2005 | 05:15 PM
Sportryder's Avatar
Sportryder
Okay, found the wires, cheaper to pay for an installation but thanks for the help. Also, thanks to Mike McCoy for an intelligent answer regarding the pouch. As for the rest of the pouch hints, well, thanks to Mike McCoy for the intelligent answer.
Brett
Old Nov 26, 2005 | 10:15 PM
Bullet's Avatar
Bullet
Old Nov 27, 2005 | 12:03 AM
edensknight's Avatar
edensknight
Originally Posted by rws.1
Is it ticking?
To Mystery Pouch - Help Needed
