Help... Rear Rotors..
Old Nov 26, 2005 | 08:05 PM
Z06_ownsu's Avatar
Z06_ownsu
Default Help... Rear Rotors..
HI,
I cannot get the rear rotors off of my car. I bought some drilled/ slotted to install. I can get everything off but the rotor. I had the E brake OFF. car was not in gear. Is there a write up or a step by step to get the rear rotors off? I know it has to do with the E brake. Thank you
Old Nov 26, 2005 | 08:37 PM
SGT. PYLE's Avatar
SGT. PYLE
Use a rubber mallet and tap on the rotor. Make sure to tap the entire rotor (12,6,3,9 oclock) and it will come off. I am sure you have removed the retaining washers on the wheel studs right. Good Luck.
Old Nov 26, 2005 | 08:43 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
YOU MAY HAVE TO USE FORCE...
Old Nov 26, 2005 | 08:54 PM
Z06_ownsu's Avatar
Z06_ownsu
i have hit the rotor with a hammer. The rotor is loose on the hub. I just cant get the rotor off the hub, But it IS loose. I know its the EB i just dont know how to get it off.
convertible lover's Avatar
convertible lover
When I did mine one came right off, the other was stuck good. I just got a good size hammer started hitting it, hit, turn quarter turn, Hit, turn quarter turn, hit again, kept it up till it came loose. did not care if I scarred it up. I did not plan on using it again anyway. It was just stuck with rust I think. Good luck on getting it off. Just make sure you did not forget to take something loose, then use a little force. Good luck.
Old Nov 26, 2005 | 09:09 PM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
Try walking it off. Its probably hung up on the e-brake pads. Just pull left then right and repeat. It'll drag over the pads a hair at a time. Worst case scenario is you pull the pads out too far in the rotor - and the spring comes off, but you can put it back on easily enough.
Old Nov 26, 2005 | 09:42 PM
Z06_ownsu's Avatar
Z06_ownsu
is there a write up with picks for the rear rotors?? does any1 have one online?
Old Nov 27, 2005 | 12:55 AM
Z06_ownsu's Avatar
Z06_ownsu
Im trying to finish this today..... any1?
Old Nov 27, 2005 | 07:09 AM
Lancer033's Avatar
Lancer033
did you unhook the e-brake cable?
http://www.klh-racing.com/brakes.htm
Old Nov 27, 2005 | 09:02 AM
Dark-Knight's Avatar
Dark-Knight
Get a BIG hammer and hit 'em hard! You may have to do so repeatedly to get 'em loose.
To Help... Rear Rotors..
