Z06 Sway Bars - OMG
Old Nov 28, 2005 | 10:23 AM
wps5's Avatar
wps5
Default Z06 Sway Bars - OMG
Over the weekend I installed a set of Z06 sway bars in my 2000 vert and all I can say is OMG. It is a totally different car now. If you are looking for the best price performance mod you can do, this it. I ordered the sway bars from Fred Beans and the install took a liitle over 2 hours. Very easy! Next up is the 2006 Z06 shocks that I also ordered from Fred Beans.
Old Nov 28, 2005 | 10:29 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
I'm almost ready to pull the trigger on this mod as well.
Old Nov 28, 2005 | 10:31 AM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
How?
Old Nov 28, 2005 | 10:43 AM
berryj's Avatar
berryj
Also, how much $$? Do u do a lot of road course stuff?
Old Nov 28, 2005 | 10:54 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Try GM Racing T1 sways. Light years better than stock
Old Nov 28, 2005 | 11:00 AM
93aqua's Avatar
93aqua
Best mod for 250 bucks or so. Makes the car tighter in the turns, handles much better without sacrificing ride quality. its also very easy to do yourself.
Old Nov 28, 2005 | 11:02 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
I did that mod only 3 months after buying my 04 vert. The biggest difference is the absence of lean when going into a curve. With the OEM bars I would always feel like the vette was leaning into the outside of the curve. With the Z06 sways there is almost no noticable lean and the car tracks smoother. The only downside is a slightly rougher ride on uneven road surfaces and a more pronounced "skip" when driving over a bump on a curved portion of the road.
Old Nov 28, 2005 | 11:10 AM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
If you are experiencing 'skip', you might look in to adding better shocks to the mix. I installed the '04 Z06 shocks at the same time and just yesterday had a chance to try it out. I found the the tendency to 'skip' was greatly reduced from my stock setup (same road). I also have an 04 vert with about 25k miles on the orginal (non z51 shocks).
I've also lowered the car a bit and the shocks got rid of the 'bottoming out' problem I had after lowering.
So far, the only downside is that the swas/shocks have really exposed how bad my tires are.... next on the list...
Old Nov 28, 2005 | 11:22 AM
kedvesh's Avatar
kedvesh
One of the first changes I did to my C5 coupe!
Old Nov 28, 2005 | 11:37 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
I did the Z06 sway bar mods a while back, awesome!!!!
Old Nov 28, 2005 | 11:40 AM
Black 00 Coup's Avatar
Black 00 Coup
I've done the same mod and love it.
Old Nov 28, 2005 | 12:11 PM
csexton's Avatar
csexton
Great Mod
Chuck
Old Nov 28, 2005 | 01:12 PM
Want to do this mod to mine some day. Maybe after I get a new set of wheels and tires.
Old Nov 28, 2005 | 07:36 PM
rhubarb74roadster's Avatar
rhubarb74roadster
Any problems with putting these sway bars on a car with F45 suspension?
Old Nov 28, 2005 | 07:59 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Forgive my ignorance, but is there any difference between the Z06 sway bars and Hotchkis bars? The Hotchkis bars run around $500 if I'm not mistaken. Just curious.
Old Nov 28, 2005 | 08:00 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
After sitting in my living room floor for 4 mouths I installed my Z06 swaybars and shocks last week. all I can say is WOW !!!!!!!!!Very Nice
Old Nov 28, 2005 | 08:05 PM
v.vet's Z06's Avatar
v.vet's Z06
I love my Z06 sway bars.....everyone should do this mod...it's cheap and easy and probably one of the better mods for the money!!
To Z06 Sway Bars - OMG
Old Nov 28, 2005 | 08:10 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Don't forget Z06 springs.
Enjoy
navy99vert's Avatar
navy99vert
Swaybars
23mm, front; 19.1mm, rear --- FE1/Base
25.4mm, front; 21.7mm, rear --- FE3/Z51 97-99
28.6mm, front; 23.6mm, rear --- FE3/Z51 00-04
30.0mm, front; 23.6mm, rear --- FE4/Z06
31.75mm, front; 25.4mm, rear --- Hotchkis
38.4mm, front; 27.5mm, rear --- GM T1
For the price you can't beat Z06 bars
Old Nov 29, 2005 | 03:51 PM
DevilDog II
Oldtimer
Originally Posted by navy99vert
Swaybars
Thank you very much.
