Dreaded belt squeek...
Old Nov 28, 2005 | 02:00 PM
Goonie's Avatar
Goonie
Default Dreaded belt squeek...
Sunday morning on a drive home I started to notice a squeek coming from the engine compartement. Sounds like its coming from the belt. Its loudest at idle and gradually goes away after 2500rpm... What are my options here... its a y2k mn6 coupe...
ac doesnt affect the sound.
Old Nov 28, 2005 | 02:28 PM
rws.1's Avatar
rws.1
Change both belts yourself... Should cost you about $50 for the two assuming you buy GoodYear Gatorback Or Gates both with lifetime warrantly.
It is possible that it is one of the idler pulleys or the A/C clutch pulley, but I would start with the belts.
It is a 20 minutes job, done from under the hood.
I'll look for a previous post that gave me the directions to do it myself.
Old Nov 28, 2005 | 02:31 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Take a bar of soap and lightly rub the underside of the belt.
Old Nov 28, 2005 | 03:14 PM
MyVetteDream
Try this:
Take a bar of soap and lightly rub it on the underside of the belt.
Old Nov 28, 2005 | 04:03 PM
byte_me's Avatar
byte_me
Originally Posted by MyVetteDream
Try this:
that will work for a little while...but if they are stretched out or worn some...new belts should do it! I ran thru this on my 97 with 68K miles on the original belts...hour later...squeek was gone!
Old Nov 28, 2005 | 04:35 PM
Goonie's Avatar
Goonie
So i put a tiny dab of some liquid soap on the passenger side belt and poof no squeek. I think its time for new belts, y2k with 37k.
Thanks everyone!
Old Nov 28, 2005 | 06:18 PM
c0rv3tt01's Avatar
c0rv3tt01
I had a sqweak that was more pre-dominant on moist mornings, that turned into an all day thing this past weekend, a little wd-40 on the idler pulley and presto...
Old Nov 28, 2005 | 06:37 PM
coast7's Avatar
coast7
Belt squeeks that are silenced by an application of some type of lube/belt dressing will probably return, and sooner than later. A belt change is in your (near) future.
If you haven't done a belt change yourself yet, wait for the engine compartment to cool first. Find the main belt tensioner (top pulley on passenger side), place a socket wrench on the tensioner nut and push it toward the middle of the engine until there is enough slack to remove the belt. Repeat this procedure for the A/C belt, its tensioner it a little harder to reach because it is under the power steering fluid reservoir. Before installing your new belts, some here recommend cleaning out the pulley grooves with a wire brush/emery cloth. Make sure to install the A/C belt before the main belt.
Do not try to loosen/remove any nuts in this process, moving the belt tensioners is all that is needed.
Good luck
fastcop_c5's Avatar
fastcop_c5
sounds like bird chirping? i got it too. time for a belt change.
Old Nov 28, 2005 | 06:46 PM
TOPGUN9's Avatar
TOPGUN9
I had the same problem about 2 years ago. Changed both belts; problem solved! This is the easiest fix. If you still have a problem, it could be an idler pulley.
Old Nov 28, 2005 | 07:09 PM
fastcop_c5's Avatar
fastcop_c5
anyone got a link for the belts or a part number with the store that has them? i plan on getting them in the morning.
Old Nov 29, 2005 | 01:48 AM
dataporter's Avatar
dataporter
Replace the belt and the idler!! Now!! Lose the belt and it will over heat in a heart beat! Lose the belt going up the Grape Vine, tow at best new engine at worst!! Once you over heat an engine it will never be the same.
Old Nov 29, 2005 | 08:59 AM
rws.1's Avatar
rws.1
Most autoparts stores stoock them or can get them next day...
Best prices I found were at Autozone... for GoodYear Gatorback.
Just call and tell them your year and they will be able to tell you if they have it in stock or will get it next day.
Local CarQuest keeps Dayco in stock, but they are About $65 for the pair vs $50 for the GoodYear
Old Nov 29, 2005 | 09:05 AM
zo6vetteman2003's Avatar
zo6vetteman2003
I had a squeeking belt recently. Fixed it. I may have a different situation. Being a cammed car, my 240ft./lb. torqued damper bolt backed out a bit, so the alignment wasn't true and was squeeling. Torqued her back down, and squeel is completely gone.
Old Nov 29, 2005 | 10:35 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Goonie -
When you replace, use the Goodyear Gatorback belt -
They have a special cross-rib design that keeps them running quiet.
I had this problem on my K3500 truck.
The goodyear belt is more pricey - but worth it IMO.
best regards -
mqqn
To Dreaded belt squeek...
