Fatmat tar smell?
Old Nov 28, 2005 | 02:35 PM
scottydog's Avatar
scottydog
Default Fatmat tar smell?
I just got a shipment of Fatmat 100 sq ft in. Opening the box and it smells like a road being resurfaced with ashphalt. Is my car going to smell if I install this stuff?
Old Nov 28, 2005 | 03:15 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I heard others say that it has a tar smell when installed.
They pitch the FatMat product as the same as DynaMat Extreme at a much lower cost - but DME does NOT have a tar smell - the Original DynaMat did.
EG
Old Nov 28, 2005 | 03:33 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Check out the posts by MikeMercury, who has done quite a bit of research on heat/deadening solutions. If I remember correctly he talks about the "smell" issue. The tar smell was a commor problem with the early Dynamat materials.
Old Nov 28, 2005 | 06:53 PM
Mike Mercury's Avatar
Mike Mercury
yep; the Dynomat Xtreme product uses no petroleum based material. Neither does Damplifier offerings either.
Damplifier Pro is very dense and is good to 500 degrees
http://www.secondskinaudio.com/produ...hp?productid=2
Old Nov 28, 2005 | 07:06 PM
rhubarb74roadster's Avatar
rhubarb74roadster
I just installed RAMMat .. supposed to be as good as Dynamat extream .. but no smell.
Old Nov 28, 2005 | 08:19 PM
scottydog's Avatar
scottydog
The price is up there also. Maybe I'll try the Frost King mod.
I have this bad feeling that if I install Fatmat I'll be driving down I-5 mid summer, 105 in the shade, and I will be smelling ashphalt for 200 miles.
To Fatmat tar smell?
