Bump Steer
Old Nov 30, 2005 | 08:40 AM
MPLC's Avatar
MPLC
Default Bump Steer
Will someone explain to me what bump steer is? Hope that is the correct term.
Thnaks for your help!
Old Nov 30, 2005 | 08:43 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Just drive your car with runcraps - it's self-explanatory.
Old Nov 30, 2005 | 08:44 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
My understanding is that bump steer is the characteristic of the suspension to turn the wheel/tire when it is forced up either by rolling in a turn or hutting a bump. I'm sure there are others here that will have a more concise and accurate definition (and others that think they do).
Old Nov 30, 2005 | 08:46 AM
Shane_S's Avatar
Shane_S
have you hit a put-hole or something with only one side of the car, and notice that the car pulls in that direction and wants to turn in that direction. Thats bump-steer.
At least that is my understanding of it.
Shane
Old Nov 30, 2005 | 08:48 AM
MPLC's Avatar
MPLC
I don't have run flats but I notice when hitting larger bumps, it seems the front moves a bit more than any other car I have driven. I really notice it if I am in a sharp turn and hit a small hole or larger bump. The control does not feel just right when it happens. I didn't know if that is considered bump steer or I possible have worn shocks. I just had my suspension checked and the only problem that was found was a bad tie rod. That has been replaced but there was really no change in the ride.
Old Nov 30, 2005 | 12:04 PM
2KFRC5's Avatar
2KFRC5
Bump Steer:
When an uneven road surface causes a vehicle to steer or lose directional stability, this is called "bump steer." At the front, bump steer is associated with the tie-rod and linkage-arm relationship. It is caused by the method of locating the rear suspension, the type of rear suspension, and the geometry of the various linkages. In race cars, bump steer is designed out of the suspension so that the handling is as precise as possible. In most cars it is present to some degree. In fact, it can be useful to allow engineers to design a small amount of understeer or oversteer into the chassis.
Dictionary of Automotive Terms
Old Nov 30, 2005 | 12:10 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
According to my vette:
Bump steer = slow down over bumpy turns or change to non run flats.
According to me:
The weight distribution of this car is far better and much different than any other car I have driven. My front heavy z28 camaro never did it, but then again I also never caught myself smiling in the rear view of that camaro either!
Old Nov 30, 2005 | 12:13 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Originally Posted by 2KFRC5
Bump Steer:
Old Nov 30, 2005 | 04:29 PM
MPLC's Avatar
MPLC
Well after reading the post by Dave Q. and many others regarding the C6 Z06 shocks, I orderd a set today from Gene at Fred Beans. At $196 delivered, I don't think there is a better deal around. I priced a few shops in my area and the cheapest quote was $1,195 for the C5 coupe OEM shocks! Of course they all sourced the dealer for thier prices and mentioned it was best if I stayed with the C5 shock. I wonder why
As a new Vette owner, I thought I had suspension problems so I had it checked and things were as they should be. After reading many many post, I found the bump steer and rolling effect are common.
I will let everyone know if they cure my handling woes!
Old Nov 30, 2005 | 04:36 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Coolio Mike! Congrats again
C5 parts are more expensive than C6 parts for some reason... but when you're talking to the STEALERSHIP.. well... you know where that gets you now. It's like the wheel sensors for the 97-2K I believe, are almost 2x the cost of '01-'04 sensors?
It's probably the same reason we can go to Gene and get a set of OEM brake pads for about $120 and the local stealership wanted to charge me about $300 is all I can say.
Here, here to Gene and our other supporting vendors here on CF
I just hope you enjoy your ride....
Old Nov 30, 2005 | 04:46 PM
Mike McCoy's Avatar
Mike McCoy
Bump steer is when the wheels (one or both) toe in or out when the front of the car moves up and down. Same for the rear. For safety this should be as little as possible. That being said, setting suspension up for road racing/autocross can and does become very technical and should only be done by an experienced person. The factory sets up their cars for safety, tire life, gas milage, etc.
Old Dec 22, 2005 | 10:15 PM
MPLC's Avatar
MPLC
I have had the Z06 shocks installed for a week now and the feel is much tighter than the stock C5. However, I have also noticed the ride seems stiffer or more bumpy than the C5 coupe. How does the feel of the Z06 shocks compare to the Bilstiens?
To Bump Steer
