[Z06] 4th Gear Noise
Old Nov 30, 2005 | 01:37 PM
intense1's Avatar
intense1
6th Gear
Default 4th Gear Noise
Has anyone experienced a slight rattling sound, almost like the sound of an exhaust leak when you step on in it in 4th gear? It only occurs in 4th and only when cruising at 65-70, until you reach about 3,500 RPM's.
Old Nov 30, 2005 | 03:13 PM
DPG's Avatar
DPG
St. Jude Donor '06
No sorry, havent had that happen to me....ttt for ya
Unless its the H-pipe thing that people have had problems with, where a little piece comes loose in the h-pipe and they fixed it by installing a x-pipe
Old Dec 1, 2005 | 01:51 AM
TheDVS1's Avatar
TheDVS1
Put your hand on the shifter when this occurs and see what happens. Could be shifter rattle, especially if you've messed with your stock shifter. Ever since I cut mine down slightly, I get a bit of a rattle under certain conditions. I didn't leave a deep enough groove for the demon key, thus it doesn't attach the **** as firmly as before and it rattles ever so slightly. YMMV.
To 4th Gear Noise
