"Column Lock Rehash"
Old Nov 30, 2005 | 02:29 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Default "Column Lock Rehash"
Sorry about this one, but I only found you guys about 3 wks. ago, I know, "what' up with that?". Anyway I was sent a recall notice about a year ago, and was fixed. Is there a problem with the new one? I can't tell you how much info and enjoyment I've gotten from you all. Will be sending $$$ shortly. (2000 cpe)
Old Nov 30, 2005 | 02:31 PM
itsmeek's Avatar
itsmeek
the dealer fix is not effective. or so i've been told. get the clb that is sold by vendors on this site.
Old Nov 30, 2005 | 02:37 PM
torchredfrc's Avatar
torchredfrc
Corvettes of Houston have the CLB that I installed in my 99 after having several issues & the dealer recall performed. It's well worth the money to have this issue fixed. If, however, your car is a automatic then the dealer recall is effective if performed correctly.
Old Nov 30, 2005 | 03:38 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
The dealer "fix" doesn't fix the problem. The only sure fix is to get the Column Bypass Lock. A number of Forum vendors offer these. Get it....easy intall and Forget it.
Old Nov 30, 2005 | 04:00 PM
bozo4onion's Avatar
bozo4onion
Dealer "fixed" mine. Year later, Computer tells me "pull key wait ten seconds". Mine restarted. This computer warning is your last. Column may lock at any time. Get the bypass now. Installed mine last month. Me Y2K too.
Old Nov 30, 2005 | 04:45 PM
fatboytc88's Avatar
fatboytc88
I Experienced The Dreaded Coloum Lock Today Except It Was Not On A Corvette But On My 04 Dodge Dakota. I Had A Can Of Wd 40 Squirted It In The Ignition Lock And It Cured The Problem.
Old Nov 30, 2005 | 05:10 PM
I'd spend the $50 or so and get the column lock bypass installed. Better to be safe than sorry.
Old Nov 30, 2005 | 06:35 PM
rws.1's Avatar
rws.1
My MN6 '01 had the dealer recall done twice.
I still had the dreaded column lock.
Luckily,I was able to free it. 3 days later the Corvettes of Houston CLB was in it... I have been sleeping well since then....
Old Nov 30, 2005 | 06:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'd recommend you give this thread in C5 Tech a read. It has a ton of great information on the column and its issues.
Paul
http://forums.corvetteforum.com/show...483&forum_id=1
Old Dec 1, 2005 | 02:24 PM
Herringchoker
Thanks for the info!
Old Dec 1, 2005 | 02:29 PM
C6~Missle's Avatar
C6~Missle
Bypass the POS...
To "Column Lock Rehash"
