C5 Convertible Top Rear Window
Old Nov 30, 2005 | 08:43 PM
carguy1507's Avatar
carguy1507
1st Gear
Default C5 Convertible Top Rear Window
Hi to Everyone - New User Here!!
Have a tech. question on '98 convertible rear window - the rear window came loose from the top material leaving the 'heat set' adhesive strip intact on the top material. Dealer and National Service both say new top $3400 plus labor. I don't want to buy a new car, just reattach the window, which by the way has safety straps to prevent crashing, so becoming unglued must have been foreseen though I can find no one who will admit to having ever seen one come loose. I need a recommendation for best adhesive to use to reattach glass to strip on top. Anyone seen this before?
Thanks Carguy
Old Nov 30, 2005 | 08:48 PM
1998 GTR's Avatar
1998 GTR
$3,400 for a top? Must be the dealership price. I think MidAmerica has them for under $500. They are a supporting vendor. Check the vendor section. They might also be able to tell you how to fix yours. I hear they are very helpful to work with.
Good luck!
Old Nov 30, 2005 | 08:56 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Thanks Carguy
$3400! And they wonder why people try and avoid them.
Old Nov 30, 2005 | 09:33 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Thanks Carguy
I had this same problem with an Fbody rear window. VERY common problem on them and I've seen several comments about it on C5s too. I used 3M trim adhesive to repair mine, but the results were temporary. You probably already know it costs as much to replace the window as to get a top. IMO, you should find out who installs tops in your area and visit them about the window. I don't think you find a permanent fix, but you might avoid having to replace a top.
Also do a search... there was a recent thread on this an some had good suggestions on adhesives.
HTH
Old Dec 1, 2005 | 07:00 AM
VinnieR's Avatar
VinnieR
From: Austin, Texas 2005 National Champs in Football and Baseball.
Convertible tops are best left to experts. The penalty for doing it wrong is too great. Recommend you find a reputable, independent top shop near you and seek their professional advice and assistance. It won't cost any where near $3400 and you'll get a first class job.
Old Dec 1, 2005 | 07:48 AM
rapid robert's Avatar
rapid robert
There was a post on here about using JB Weld and he said it was holding for a year and a half. Maybe do a search and see if you can find it. Good luck
Old Dec 1, 2005 | 08:04 AM
Shane_S's Avatar
Shane_S
I Love JB Weld. But i'm not sure about using it on a surface as smooth as glass. I say hit up MidAmerica.
Shane
Old Dec 1, 2005 | 08:19 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Shane
I'd say use the JB weld!
I'm one of the people that used the JB weld on the rear window glass, it's still holding after more than 1 1/2 years.
I couldn't see buying a new top just because the rear window adhesive wasn't holding anymore, I priced a new top at around $350.00 and another couple hundred to have it installed at a local shop that specializes in convertible tops and interiors. ( NEVER take the car to the dealer, they'll rape you EVERY time!)
Old Dec 1, 2005 | 10:27 AM
mikeam's Avatar
mikeam
This just happened to me 6 weeks ago. Bad timing too because I was going to close on selling my house and relocate down south. Went to Home Depot and found "Perfect Glue 2", made my Liquid Nails. They had a perfect glue 1 but #2 sounded like the right one to use. I put in on with the top up, ran a bead from where it separated in the middle of the window all the way across to the other side. Then I applied pressure with 3 rolls of paper towels and let it sit for 3 hours. Once I settled on the house, I drove 500 miles to SC, drive started with lots of rain from N. VA. thru Richmond, VA. Still holding good at this time, this on a 2000 vert.
Old Dec 1, 2005 | 10:41 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Well I'll be darn! My window fell out last summer in the pace car. It was successfully glued back in by the shop we used at the time. I don't remember the type adhesive used but mine too has stayed in and the top goes up and down all the time!
Old Dec 1, 2005 | 12:11 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Great to hear some got it glued back!
I got my replaced 2 years ago using GM top for $1100 and $500 labor.
-Mike
Old Dec 1, 2005 | 05:25 PM
sage666's Avatar
sage666
JC Whitney also sells complete replacement tops with the defroster glass for $750. Got a lot of other stuff for the C5 also.
Old Dec 1, 2005 | 06:42 PM
vet85's Avatar
vet85
happened to a buddy of mine ,so he carried the car by an upholstery shop they fixed it . :: dont recall how much but he said it was very cheap.
Old Dec 1, 2005 | 07:52 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks Carguy
When I first got my 1995 Vert the window came unglued from the top and I took it to a car upholstery shop and they used 100% black silicone from a cylinder shaped tube in a calk gun...They let it set up overnight...I think the silicone was made by GE...its like $5 a tube and it has held now for 5 years. They charged me $75......
To C5 Convertible Top Rear Window
