[Z06] Help! Question about possible purchase
Old Dec 3, 2005 | 07:02 PM
stook1's Avatar
stook1
Default Help! Question about possible purchase
Hello - I just put a deposit down on an 02 Z06 from a dealership. The car has 6000 miles and carfax is clean. Its a 1 owner vehicle...
I haven't looked at many Vettes and was hoping to find out whether something I noticed was normal. The upper edge of the doors where they meet the front fender (ie. right by the windshield). Should the panel fitment be identical on both sides of the vehicle? On this car, the driver's side door seems to stick up slightly higher than on the passenger side (relative to the fender). One side sticks up maybe 1/4" whereas the other side seems perfectly even with the Fender edge. Both doors open and close normally. I did not notice any obvious bodywork (ie. overspray, color issues, etc.).
Any help would be appreciated... I just don't know these cars well enough to know how good the panel fitment is from the factory. Oh! Also, can anyone recommend a Corvette specialist in the Hartford/Danbury CT area. The dealer is in the western suburbs of Hartford and I plan have the car looked over by a 3rd party.
thanks!!! Zach
Old Dec 3, 2005 | 07:58 PM
bb609's Avatar
bb609
thanks!!! Zach
I just bought an '03 a week ago so sort of a newbie but I do know what to look for in a used car. The fit and finish on my car is impeccable. I'd dig a little deeper into yours, gotta be a reason why it's out. I can also show you at least 3 mint low mileage '02's within 20 miles of me in Southern NH. Shop around, it pays.
Old Dec 3, 2005 | 08:43 PM
slong's Avatar
slong
Can you post some pic's for us to check out?
Old Dec 3, 2005 | 10:09 PM
stook1's Avatar
stook1
Unfortunately, I didnt have the camera with me when I was at the dealer.
Old Dec 3, 2005 | 10:55 PM
DJ:BOTA's Avatar
DJ:BOTA
I currently work, and have worked at several dealerships. There are plenty of imperfections even with $50k cars. I wouldn't worry about it......
Old Dec 3, 2005 | 11:49 PM
bluestreak63's Avatar
bluestreak63
Did you check the lower portion of the door to see if that gap was off as well? I mean there are some imperfections on these cars...no car can be made perfect, after all...they are made by machines which are programmed and calibrated by humans.
Old Dec 4, 2005 | 12:19 AM
stook1's Avatar
stook1
Yah, the door looked pretty straight to me. The tolerances on the actual gaps in the doors looked good. Doors opened and closed fine..It was just this one detail that seemed off.
Old Dec 4, 2005 | 10:11 AM
Andy64's Avatar
Andy64
My 04 Z which I bought as new had a minor misalignment with the front driver side fender with door (towards the bottom). On first oil change, I mentioned to dealer and they adjusted it for me. I suspect panels shift somewhat with body flex during normal driving and/or from being lifted during service. This is definitely a car to own/enjoy for its pure performance and handling characteristics for an everyday reliable driver. I learned to overlook minor flaws that shouldnt exist on a 50k car, by knowing that to get comparable performance on a stock car would cost at least 40k more anywhere else. Otherwise I probably would drive myself insane ... lol
Best of luck and enjoy if you chosse to make this purchase.
Old Dec 4, 2005 | 10:34 AM
pdqz06's Avatar
pdqz06
most, from my experiences are off a little here and there,what i might consider fine, you may consider off by a mile.....im sure all is well
Old Dec 4, 2005 | 11:15 AM
stook1's Avatar
stook1
My prior experience is mostly with Japanese cars which I guess have better tolerances for these sorts of things. If its off from the Factory, I really dont care, just trying to cover all bases on possible collision damage. thx! Zach
Old Dec 4, 2005 | 11:18 AM
bb609's Avatar
bb609
1/4" is normal?
Old Dec 4, 2005 | 01:46 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Some things I checked for on the 01 I just picked up. 1) make sure you look at the car up on a lift. 2) Notice how the car has been lifted in the past. (these cars need to be lifted in a certain way, as not to cause lower body damage) If you can't get car on a lift do what I did buy a long mirror and slide it around under the car. This works very well. Check for any missing fasteners, or signs of a repaint. Take your time check everything. When I was after my 01 I was very picky about overall condition and service records. Another thing to look at is the bars in the very front. (due to these cars being so low, there is no way to have ones that are perfect). However if they are very bad it may suggest that perhaps the past owner, was not as careful as he should of been. Go through all the codes. Check wear on the tires, as they are not a cheap date to replace. Also check for pits on rims (as most i looked at had some pitting due to gm's poor coating. Above all be very picky and remember it's your money that your putting down. Take your time. Best of luck Sixty4.
Old Dec 5, 2005 | 07:30 AM
PA Z06's Avatar
PA Z06
my passenger side fender is the same way, its never really bothered me. I guess it all about tolerences. Good luck.
To Help! Question about possible purchase
