Installing Rotors and Pads
I found this write up .... are there others??
http://dana60.com/rickko/corvette/rotor-rr.html
Thanks,
DH
look behind the rotor and you'll see the cable. Just use a screwdriver to pry it off
I've got a few comments on brakes here
I am most concerned about greasing the caliper pins that I have read about before. And the correct colored locktights to use. I want to be able to get everything apart, especially the rotors the next time.
DH
1) The rear bolts cannot be gotten off with a breaker bar. There is not enough room. You absolutely need an impact wrench and you will probably have to soak the bolts with pennetrating oil.
2) The thread does not address the REPLACEMENT of pads, only rotors. You will need to push the pistons back in the calipers. Get yourself a large "C" clamp and a piece of 1x2 about 6" long. Use the wood across the pistons and wind the clamp across the caliper to push the pistons back. REMEMBER! You have probably added brake fluid as you have used up the old pads. When you push the pistons back in the original place, you will push the excess brake fluid back into the reservor, and probably over flow it.
Other than those two problems, the job is really simple, GO FOR IT!!!
ZOOOM
DH
ZOOOM
I am not removing the rear rotors....only the fronts. But I am surprized to hear that an impact wrench is necessary......I thought lots of guys were doing this with only hand tools.
DH
I looked at my Erradispeed replacement rotor rings and there is now waxy coating.....they are zinc plated/washed.
PS: I am just replacing the front rings....these are two piece Erradispeeds......so you have to remove the ring from the hat.
DH
Car only has 54K EASY miles on it ...
should this really be a concern??
DH
DH
You won't need an impact wrench for the rear bolts, just put your wratchet or breaker bar on the bolt then give it a few good whacks with a dead blow hammer (the heavy orange plastic one).
If you are doing this work yourself, and live in a house (i.e. you have a garage) I recommend getting a compressor and impact wrench. The two I have cost me ~$300 total and I don't know how I ever lived without one. It makes EVERYTHING more enjoyable and will pay for itself in time/energy/fun in no time.
When I replace the rear bolts I just use blue loctite (vs. the red that's on there) and tighten with the impact gun. This keeps then in place,and they are easier to change. I typically don't put more than 2k miles on them between changing from street to track rotors anyway, so it makes life much easier.
Always inspect the lines if you have everything off for brake work anyway. In fact, I recommend having someone depress the pedal and then feeling each line for possible bubbling under pressure. I've seen you post about tracking, and wanting to track, and it's always a question of better safe then sorry. (never depress the pedal with calipers off or no pads in the caliper!
).I have a Dremel tool and use a little wire wheel (looks like a brillo/sos pad thingy) and this is perfect for cleaning the hub. Does a quick, clean job.
Other than that I think everything above covers it.
To change pads you only have to undo one of the 'slider' bolts, not both, and none of the caliper mounting bolts. The sliders require two wrenches (I forget sizes) in order to loosen them. Undo the top one and rotate the caliper away from the rotor (still attached by the bottom). This is all that's required to change pads, and it's identical to the front.
Changing rotors requires dismounting the caliper. From posts on here, some people are VERY strong, or there is variation in how tight those things are from the dealer/factory. Mine were a major PITA. I can only get the car 18" off the ground in my garage, which is hardly enough room to get my 24" bar on there, let alone turn it.
Thanks!!!
