I did rear bolts and cranked down the front screws as far as they would go. I trimmed the bump stops on the shocks also. I saw a Vette on here once that was in the dirt . Does anyone know how to put my car down even lower. Any input would be greatly appreciated.
Longer rear bolts and remove the front bolts completely.
Yes, that will do it! I lowered mine by cutting the front bushing off completely and leaving the bolts in and getting longer bolts from west coast corvettes. I don't think it would possibly be any lower and be driven!
I cut the crap out of the shock snubbers, do you have a decent ride or does it pound the bump stops. Mine hammers the bump stops already. Is there another suspension stop other than the hard foam one on the shock shaft?
Well, if the road is in less than perfect condition the ride hits pretty hard (I have the Z51 suspension). Upgrade to bilstein shortened sport shocks if you can't take the bumpy ride. They go for about $300 shipped for a set of 4. This is the route most take to improve ride quality after lowering.
Sorry, but a quick question please!
I have the same tire wheel, combo you do, and I can't get mine that low without occassional tire rub in the rear!
I had the rear this low, but had to raise it back up
I think it's because the tires slightly stick out more than stock.
You don't have this problem Ice??
Do you happen to know the part number for the shocks. I asked around and no one seemed to know of a shorter shock. I really appreciate the info.
No, I dont have any rubbing problems. But, we have different tires. I have pirelli p-zero rossos 275/30/19 and 305/30/19. It looks like you are running the BFG KD2's?? From the pic you can tell your tires have noticably higher sidewalls than mine. What are the specs of your tires?
I wonder if that's it
pilot sport 295/35/19's.....yours are actually wider though,accoording to the specs
