Sway Bar Question
Old Dec 6, 2005 | 07:47 AM
PEW01's Avatar
PEW01
Default Sway Bar Question
How much difference in length is the Z06 Sway Bars from non Z06? And do they bolt on differently?
Old Dec 6, 2005 | 08:51 AM
chasswartz's Avatar
chasswartz
same length, bigger dia. bolts on the same , with Z06 bushings.
Old Dec 6, 2005 | 08:52 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Old Dec 6, 2005 | 09:08 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Base Suspension: 23mm-front / 19.1mm-rear
Z51 (97-99): 25.4mm-front / 21.7mm-rear
Z51 (00-04): 28.6mm-front / 23.6mm-rear
Z06: 30.0mm-front / 23.6mm-rear
Hotchkis: 31.75mm-front / 25.4mm-rear
T1: 38.4mm-front / 27.5mm-rear
Old Dec 6, 2005 | 09:24 AM
PEW01's Avatar
PEW01
Thanks, My son bought a Complete suspension, and requested Z06 Sway Bars with it. The Front Bar is the same size of the one on my 01 coupe as for diameter, however the length is different, (not as long ). The rear is bigger in diameter and looks to be the same length. I have no idea what the front is suppose to fit. Thanks for the info.
Old Dec 6, 2005 | 10:29 AM
torchredfrc's Avatar
torchredfrc
Post pics of the bars. Are you sure you don't have them backwards?
Old Dec 6, 2005 | 10:50 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Here's a side by side... obviously, the thicker ones are the upgrades.
Backs...
Fronts...
Old Dec 6, 2005 | 11:07 AM
PEW01's Avatar
PEW01
Boy am I RED FACED, call me yaw gnorw, I should have stayed in bed.
Old Dec 6, 2005 | 12:53 PM
Same length and bolt on the same, just a bigger diameter bar - makes a lot of difference in the handling of the car.
Old Dec 6, 2005 | 08:01 PM
edensknight's Avatar
edensknight
Whoa! SuperDave to the rescue, again. Dave, those are great pics, good buddy! Thanks for sharing.
Old Dec 6, 2005 | 08:14 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Glad you got it sorted.
To Sway Bar Question
