Whats the difference between active handling and traction control?
Old Dec 6, 2005 | 06:42 PM
tlk9's Avatar
tlk9
Default Whats the difference between active handling and traction control?
Old Dec 6, 2005 | 06:45 PM
rws.1's Avatar
rws.1
Traction control stops wheelspin on launch
Active handling senses the directional movement of the car relative to the direction of the sterring wheel and adjusts by cutting the throttle and intitiating the abs system on the approriate wheel to correct the direction of movement.
Old Dec 6, 2005 | 06:53 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here's a couple of good articles to read for you on Active Handling:
http://www.idavette.net/hib/ah1.htm
http://www.corvetteactioncenter.com/...01agility.html
Paul
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Traction Control cuts engine power when the rear wheels lose traction during acceleration. It senses this by monitoring/comparing the difference in front/rear wheel speeds.
Traction Control was standard on all C5's.
Active Handling applies individual brakes as needed, and/or cuts power when the car begins to slide/skid sideways to attempt to straighten the car out.
It senses this by comparing all 4 wheel speeds, yaw rate, plus steering input sensor.
Active handling was an option on C5's starting in 1998, and became standard on 2001 and later models.
Old Dec 6, 2005 | 06:57 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
In short, one assists handling and the other traction.
Old Dec 6, 2005 | 07:04 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
In short, what my boy Tom said! When this man speaks, you had better listen.
Old Dec 6, 2005 | 07:08 PM
tlk9's Avatar
tlk9
ok . thanks..you guys are good. lol
Old Dec 6, 2005 | 07:48 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Interesting reading on Active Handling
To Whats the difference between active handling and traction control?
