Escalating a C5 problem with GM??
She has had it in the dealership 5 times now for ABS problems. Her indication is always the "Service ABS" warning. Dealership told her it was a sensor first. Replaced it. Then next it was a different wheel's sensor. Then it was something to do with needing to replace the front sensor, caliper, rotor on the original wheel. Then 4th time it was some other excuse that didn't work. Now on the 5th trip they are telling her they've decided it must be the ABS computer and assembly (since it's the only thing they hadn't guessed at so far). So of course they throw a quote at her for $2500+ but they won't guarantee that will fix it.
So my question is how would she escalate this through GM. The dealer is just acting like she has no recourse. For anyone who has been down this road could you please let me know how the process goes and who she should contact?
PS: This is not a "let's bash GM thread". I tried searching the forum but really wasn't sure what keywords to use.
Thanks, Graham
Thanks.
Her best bet is to forget the dealer, and find a good independent Corvette shop, or at least a good mechanic who is familiar with them.
Dealership mechanics are there for one reason only, and that is to fix warranty problems on new cars. The dealership has no problem with a tech throwing a bunch of parts at a car and hope that it fixes the problem. They don't pay for the parts, and a mechanic who can swap parts fast is the one they want. The factory pays squat for diagnostic time, so the mechanic is money ahead if he just changes a bunch of parts.
Now you come in with your 5 year old car, and these guys have no idea of how to trace and diagnose problems, so they sell you a bunch of parts and hope that it fixed the problem. When it doesn't, they quote a ridiculous price so you will go away.
Find an independent 'Vette mechanic and avoid the dealership, In the long run, the time and aggravation will far outway any "policy adjustment" you might be able to wraggle the zone rep for.
But that is not the info I was looking for. I was looking for how to find the Zone/Area rep? Anyone?
She is willing to escalate this and chase after them and push the issue.
Graham
In my experience with GM everything is always normal tolerance this, acceptable vibration that. Ooops. i'm bashing again.
I have 2001 coupe purchased new and I've had most of the common problems except replacing the rings!!! Leaking diff, loose hubnut, warped brakes, sucky parking brake, window control module failure, fuel pump failure, split'n seat bolster, rocking driver's seat rails, squeaky headlight doors, door speaker rattles, and faulty hazard button which cause the signals to not work.... hmmm... I think that's about it! All of this is documented and can be pulled up by any dealership... so they can see their own track record of problems/items fixed.
I took all my problems into the dealership... documented, supporting problems from our corvetteforum threads, and GM service doc's! I got nothing but, "So what do you want us to do???" and "So we don't understand what problem you are having???" and "We've had other cars with more problems than yours!" <----- Actual quotes!!! NO polishing of the story here! They even told me that they don't like people bringing anything from the internet into their establishment!
Then I was told... Well, sorry Sir but we aren't GM!!!
Folks... the folder I brought in was thick!!! Enough supporting reading material because they will tell you that your problems have never been seen at their dealership before!!! <---What a LIE!
I spoke to a Regional Rep. and he said... "Well Sir, there is nothing I can do about a car with 40000+ miles on it! Bring it back in and we will look at it again!!!"
I also filed a case with GM and they never returned my Phone call like they promised. So I called back and basically vented on one lady... I feel bad for doing it but nobody wanted to help me. Not even an offer of a free oil change!
Honestly... I wish you luck! I hope your issues are handled better than my situation because GM and CHEVY sucks at CUSTOMER SERVICE!
Good luck
Also the manual should have the toll free customer rep number but the dealer can definitely give you the zone rep number. At least try it-it worked for me.
Good luck. Jim
I disagree with this statement because I know the auto dealership business.
1. If a dealership only made money by selling cars they would be out of business real quick.
2. If a dealership only made money by fixing warranty problems they would also be out of business real quick.
A dealer makes his money from the Service Dept. Having his service bay full of out of warranty cars is money in the bank for the dealer. The factory will only pay a small amount for warranty compared to what a car out of warranty costs to get fixed at a dealership.
Actual time taken - 24 hours
Some dealerships pay the techs a commission on parts, others do not. Suggest that you find service shop where the latter is the case. A friend who is a mechanic quit a Mopar shop because he could not handle the greed. Little old lady comes in for new brakes and goes out with a new transmission as well.
I know your problem is worse, but it sounds like they are giving the lady the run-around since she is a lady. Also sounds like they don't know how to work on vettes--I'd try another dealership.
Good luck.
I'll post back and let you know what the end result was. It might take a while...
Thanks.
Good luck.
