[Z06] The Missing Mass Air Flow Sensor Screen
Old Dec 8, 2005 | 09:30 AM
Charles7Mitchell's Avatar
Charles7Mitchell
Default The Missing Mass Air Flow Sensor Screen
While waiting for routine maintenance to be completed on my 2004 Z I was informed by the service rep that the screen was missing from my mass airflow sensor, and that this was the probable reason that my car was running 'lean'. It was suggested that whoever had installed the K&N filter system had removed the screen as there were scratch marks suggesting that pliers had been used to rip the screen off. Facing a $400 charge for a new mass airflow sensor I appealed to the service manager and ultimately to GM that I did not have the screen removed. Even the dealer's corvette specialist supported the people who installed the K&N filter who insisted that they did not removed the screen either accidentally or on purpose. A complaint filed with the dealer was received respectfully, but the service manager claimed that removing the screen would increase the car's horsepower and that the people who installed the K&N filter were known to routinely remove the screens. All of my appeals failed. He added that there were likely to be long term problems if I did not have a new mass airlow sensor installed with a screen.
Twenty four hours later the service manager called to apologize. A new mass airflow sensor had arrived from GM and it had no screen. Apparently the screen is not a part of the mass airflow sensor for the 2004 Z 06. Hopefully no one reading this will face the same hassle I did.
Old Dec 8, 2005 | 09:41 AM
C6~Missle's Avatar
C6~Missle
2004 Z06 did not have a screen on the MAF sensor from the factory. The dealer is clueless.
Old Dec 8, 2005 | 10:31 AM
zo6vetteman2003's Avatar
zo6vetteman2003
That guy doesn't even know if he is on foot or horseback. I would have alot of fun with the naysayers at that dealer after the screenless MAF showed up. At least they admitted their mistake.
Old Dec 8, 2005 | 10:37 AM
Purvis's Avatar
Purvis
LMAO..
I am new to the ZO6 world and I even know that one of the changes made to the 02's and up, was to remove the screen..
Scary stuff when the techs dont know this crap.
Old Dec 8, 2005 | 10:52 AM
RoHo's Avatar
RoHo
Man!!! I hear ya- That is double SCARY when the Service rep and or tech doesn't know that the 04 did not have a screen
Time to look for another shop
Old Dec 8, 2005 | 11:54 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Old Dec 8, 2005 | 01:22 PM
User 81424's Avatar
User 81424
At least he didn't ask if you had drum or disk brakes.
Old Dec 8, 2005 | 01:28 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Scary stuff them dealerships. So what does he say about the "plier marks" now. What a putz. You should at least be comped an oil change, just make sure that the tech remembers how to fully tighten the filter.
Old Dec 9, 2005 | 01:55 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
scary stuff out there. I found a good dealer local for the mundane stuff I will not do myslef. Good luck with finding a new dealer but at least he was honest.
Dave
Old Dec 9, 2005 | 05:32 PM
shurite44's Avatar
shurite44
Holy ****, that is scary. I don't have a Z but I know they don't have MAF screens.
Old Dec 9, 2005 | 07:33 PM
Richie Carbone's Avatar
Richie Carbone
Make a bet with the moron. Tell him to go get a 2004 LS6 MAF and if it has a screen you will pay for it if it doesn't have one you get it for free.
Old Dec 10, 2005 | 12:17 PM
saber's Avatar
saber
Does it help to remove the screen on an 01????
Old Dec 10, 2005 | 01:40 PM
Richie Carbone
NO! The screen is there to straighten out the airflow from the airbox.
On the 02's GM knew exactly how the airflows through the airbox and could get away with removing the screen.
The drawback for 02-04 owners is when someone changes to a performance air intake it will significantly change the airflow and will cause the readings to go out of whack. The easiest way to tune around that would be to swap to an 01 MAF and copy the MAF tables as well and tune from there.
Old Dec 10, 2005 | 03:25 PM
Crushinator's Avatar
Crushinator
It's amazing how clueless some dealers are. I've taken 2 of my Z06's to two different dealerships and both times they asked me if it were an automatic or 5 speed. A 5 speed! LOL!
Old Dec 11, 2005 | 08:26 PM
saber's Avatar
saber
Thanks Richie, I think I will leave well enough alone.
BTW, I changed the intake and no codes!!!!
Old Dec 11, 2005 | 08:42 PM
Richie Carbone
No problem saber.
The reason you aren't getting any codes is due to the screen still being in the MAF.
Old Dec 11, 2005 | 11:01 PM
1 Nasty Z's Avatar
1 Nasty Z
Mine has been gone since 2002.
No problems here.
To The Missing Mass Air Flow Sensor Screen
Old Dec 12, 2005 | 12:40 AM
striper's Avatar
striper
On my '98 I removed the screen, installed a Vortex intake and polished the MAF ends and trimmed the blade in the middle. Worked great and never had any codes or other problems. I know it worked because with no other mods lowered E.T. at the strip.
Old Dec 12, 2005 | 05:43 AM
Joe C's Avatar
Joe C
sometimes i wouldn't trust the tech to that right...
Old Dec 12, 2005 | 01:29 PM
DaBeast's Avatar
DaBeast
so is it good to descreen the MAF if it has a screen?
