[Z06] Perfect Z-06
Who is problem free with the Perfect Z0-6
Some problems I've heard each one most likely affects a small %
1.Oil use
2.Rocking seats
3.Sticky clutch under hard use
4.Front tire wear inside
5.Valve train noise
6.Transmission popping out of gear
7. Battery drain
8.
There is more... chime in
2.Rocking seats - not a problem here
3.Sticky clutch under hard use - no problem
4.Front tire wear inside - not yet... can reduce negative camber for street use. Designed that way for neutral handling. can be dialed in to prevent inside wear.
5.Valve train noise - sodium filled valves, high lift.. All normal.. its not noise... its the nature of the beast.
6.Transmission popping out of gear - 6 years and 3 C5's, never had this problem.
7. Battery drain - out of town for 3.5 weeks... started up no problem..
8. No car is perfect.. the Column lock is a POS but I have it bypassed.. The seats suck, the steering wheel is too big,
9. The rear tires keep slipping...
1. Oil Pump went out at 8k miles....
2. Front inner tires to cords at 24k miles...
3. Too much Fun....
4. Gr8 first new car i have every bought (graduated school..got job...purchased car...
5. No regrets....Life is Great!
Guess it is best to "get it out of the way" before the warranty expires.
3.Sticky clutch under hard use - yep by end of qtr pedal grabs on floor
5.Valve train noise - normal and i dont notice it... often
6.Transmission popping out of gear - not if you put it in gear...all the way
7. Battery drain - shipped car from florida to hawaii and started instantly
8. No car is perfect.. the Column lock is a POS but hasnt got me yet
9. Cant find traction on street....
My only complaint is the amount of break dust. Pretty minor complaint.
Especially #9
1. Motor mount gel leak (warranty fix)
2. Rear diff. leak (warranty fix)
3. Cracked gas tank filler neck (warranty fix)
4. Column lock recall issue (warranty fix)
5. Check engine light came on after putting gas the other day - going in
for a checkup on Wednesday. The car is running fine though, so I'm
not overly concerned about it.
Number 5. turned out to be a crack in the right side gas tank. They
ordered me a new tank, but it takes 7-10 working days for it to arrive.
This is also a warranty fix...
tires, yup my SC got corded when my front end got thrown off on a wierd bump in the road...
Clutch: bingo passes at the track did the sticky thing, but it held up to my less then good driving and about 70 passes before it was replaced
3rd gear syncros poof at the track
battery cool
seat cool
tires spin but not becuase I am doing something I should not, it's just the extra HP and torq
BIG Problem: need more mods
Dave
Leaky rear diff seals,,,,,fixed under warranty.
Noisy Valve train,,,,yup, but that's my fault! Heads/cam pkg. will tend to make it somewhat noisy, but it's music to my ears.
Rear tire slip,,cured by Nitto 555r D/R's
Absolutely love the car,,17k miles of grins!
Jim
