Frame Damage From Lift Pads?
Old Dec 12, 2005 | 03:10 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Frame Damage From Lift Pads?
Over on the C6 Forum, someone claimed that using hockey pucks or the BMW lift pads on your frame for jacking points, can cause the frame to be dished or dimpled in that area. The idea is that the pucks/pads concentrate the weight in an area that is a little too small to take the stress, and distorts the frame slightly.
Has anyone seen this problem?
Thanks.
Old Dec 12, 2005 | 03:16 PM
BlackArrow's Avatar
BlackArrow
Thanks.
No problem I have found with my hockey pucks....I would think that what you describe would be virtually impossible.
Old Dec 12, 2005 | 03:36 PM
silverstreak01's Avatar
silverstreak01
Goes to show you, they don't build the C6 as good as a C5.
Old Dec 12, 2005 | 03:44 PM
yellow01's Avatar
yellow01
My understanding is the tow hook areas are actually rivetted inserts in the frame. I've heard of one person pushing one of these in by jackign at that location (over 5 years+ of C5 ownership).
I've also heard plenty of anectodal discussion that lifting at these points 'twists' the frame. This is likely true to some extent - heck simple physics says it would occur.
As far as permanently distorting the frame, I would think this is unlikely; but again, this is simply anectodal.
I typically lift from the crossmembers unless I'm doing a quick tire change.
Certainly, if you are using jack stands, I'd recommend using them on the x-members than the tow hook inserts on the off chance that one of the rivets does fail (again, I've heard of one in the last 5+ years).
Old Dec 12, 2005 | 04:08 PM
Merlin02's Avatar
Merlin02
You're absolutely correct. The hard pucks can dent the frame. I used a set of the hard black plastic square jacking pucks from Eckler's. They're called jacking pads and they're the type that snap into the tie down holes and remain on the vehicle full time. They did dish the jacking points on the frame after being used only a couple of times to jack up the vehicle. This was very apparent when I had the plastic pucks removed and had Andy at A&A, install a set of rail savers. The jacking points on the frame were obviously dished upward from using the hard pucks.
Old Dec 12, 2005 | 04:12 PM
Goonie's Avatar
Goonie
hockey pucks ftw!
Old Dec 12, 2005 | 04:14 PM
5.0_CJ's Avatar
5.0_CJ
Thanks.
even if that happened, which I doubt it would, a dimple or dent on your frame means nothing, besides that being ubsurd.
Old Dec 12, 2005 | 04:19 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I use the aluminum ones and yes they have left dimples in the frame rails.
edensknight's Avatar
edensknight
Old Dec 12, 2005 | 04:33 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
When you lift around 900 lbs from a point as small as the jacking puck... it's gonna happen.
Old Dec 12, 2005 | 04:59 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Thanks.
1. No, I haven't seen this problem (on 5 C5's I've owned).
2. To some, minimal, extent there will be 'twist' at a given point when lifting the Vette off the ground at that given point. The real question: does this cause issues - the answer is no.
As stated by others, many elect to 'jack' the Vette up, for example, at the rear suspension. It is easier to do this method, and since once jacked up you can insert floor supports this allows you to do a lot more work in a shorter time frame that lifting one area at a time.
In conclusion, I would not pay much attention to the person posting this nonsense.
Old Dec 12, 2005 | 05:10 PM
darkmercury's Avatar
darkmercury
HOCKEY Pucks!!!
Just lift from the cross-members... front and rear!
Old Dec 12, 2005 | 05:20 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I have had the BMW pucks on for almost 2 years. No problems yet.
Old Dec 12, 2005 | 05:41 PM
sage666's Avatar
sage666
Just installed the A&A frame rails and that solves the entire problem. Just put the jack on the rail and lift anywhere. BTW, used my 1500lb motorcycle jack for the install and it worked beautifully! The frame rail balanced on the jack and both slid right under, with about 1/2" clearance.
Old Dec 12, 2005 | 07:49 PM
indy300's Avatar
indy300
See the picture below. The shades kind of blur but here is the information: GM's service information recommends lifting at the cross members as primary and at the side rails as a third option. Although there is not "second option" for lifting at the rear.
Old Dec 12, 2005 | 08:00 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Bingo
Old Dec 12, 2005 | 08:12 PM
EscapePod's Avatar
EscapePod
Pardon my laughing at GM's sketch , but unless I'm not seeing it clearly, it appears they rate the bottom of the car's tires as the 4th recommended lift spot. Isn't that the part that supports the car full time while driving it down the road (and even while its parked)?
To Frame Damage From Lift Pads?
Old Dec 12, 2005 | 08:45 PM
indy300's Avatar
indy300
Yes, you are seeing it clearly...
Old Dec 12, 2005 | 09:00 PM
tsts's Avatar
tsts
Hockey Pucks! We don't need no stinking hockey pucks.
Old Dec 12, 2005 | 11:12 PM
TEXHAWK0's Avatar
TEXHAWK0
Kent Moore Tool makes a set of jacking pucks (part # J-43625) for GM Dealers specifically to fit the side frame on the Corvette. The only problem with them is that they are not thick enough to use a floor jack and keep the saddle from getting into the rocker panels, so I had a set of aluminum ones made at a local machine shop that is similar to the aftermarket set available.
I have used them for a couple of years now and can detect no noticeable frame deformation in the area where the pucks fit into the frame.
