C5 and Motorcycle Jack
Old Dec 12, 2005 | 05:45 PM
sage666's Avatar
sage666
Default C5 and Motorcycle Jack
Just installed the A&A frame rails using my 1500lb motorcycle jack for the install and it worked beautifully! The frame rail balanced on the jack and both slid right under, with about 1/2" clearance. Positioned the rail and pumped the jack up about six inches. Used a right-angle attachment on the drill for the screw holes. Can now lift the entire side of the car at once anywhere along the rail.
