Hypertech users.
Old Dec 15, 2005 | 05:07 PM
sacstyl's Avatar
sacstyl
Default Hypertech users.
Well i guess nobody in Tech has used one of these.I'll try over here.Could somebody give me a few examples of there numbers they used with this unit for A4. Thanx
Old Dec 15, 2005 | 05:19 PM
Humy's Avatar
Humy
I used it, but I am of no use - I can't remember the numbers I used - my mechanic set it all up during my 3.42 and TC swap
sorry
Old Dec 15, 2005 | 05:21 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Besides the "tuning" I would touch nothing else. Unless you changed gears or the stat, I would change the fan setting etc.
Old Dec 15, 2005 | 05:29 PM
sacstyl's Avatar
sacstyl
I thought there best feature was for the auto Trans.
Old Dec 15, 2005 | 06:33 PM
Mike Mercury's Avatar
Mike Mercury
the reason is because the HP III has a bug when used with the C5. It won't gear scale an A4 properly when changing rear axle ratios beyond the 3.15
Hypertech refuses to make any corrections or updates to fix the bug. And they won't refund anyones money.
But not all is lost... if you never intend to change rear axle ratio on an A4... then the bug will never be a factor in its useage
To Hypertech users.
