The rear's don't look big enough to be 20's..bad pic angle, I could be wrong. I have 19/20's on mine, so I can usually tell. I'm guessing 19's all around.
BFG is short for BF Goodrich tires.
Thx guys. I'm obviously a rookie in the car world. Getting my first vette on Jan 9th. Used '97 C5 with 12k miles and I want to put some rims and tires on it.
While I'm at it, is there any big disadvantage to putting the same sized tire on all 4's or should I stick to the same ratio as the stock wheels?
There's nothing wrong with running the same wheel size all around, as you can just stagger the tire sizes a bit to keep the rear tires a little taller (which IS important).
I'd suggest a 19/20 combo with 275/30/19 and 285/30/20 tires.
If you want 19's all around, a 275/30/19 front and 295/35/19 rear works well. A 305/30/19 can also work nicely in the rear, but you'll need a minimum of 10.5" wide wheel to run it...I didn't note what widths these wheels were available in.
Good luck on your new ride and welcome to the forum.
The biggest size they come in (as far as I can tell) is 20x10 and 19x10. Will that work? If so, what size of tire would I want on them? Any recommendations on a good wearing, quiet, good priced tire? I'm mainly going to cruise the car. I live in Arizona, so heat is a factor and rain/snow won't be.
