What DIC Code Is This???
Old Dec 21, 2005 | 09:53 AM
schtick's Avatar
schtick
Default What DIC Code Is This???
TCS-C1248 came up on my DIC and I dont see it on the site that tells you what they are. Does anyone know? Car also threw C1225 but that one was on there.
Old Dec 21, 2005 | 10:24 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
C1248 is LF excessive wheel speed variation and 1225 is EBCM turned on red brake warning indicator on. Not sure what causes these but there they are. Any problems with your brakes that you notice??? Good Luck.
Old Dec 21, 2005 | 10:29 AM
schtick's Avatar
schtick
I just had my calipers powdercoated but no appearant problems with the brakes, they seem to work fine. I wasnt braking or anything when the code showed up. I did, however, have to remove the wheel weights on the front wheels because the dip s!#$ts that mounted/balanced my tires put them on the outside of the wheel so they dont clear the caliper. I cleared the codes, shut the car off, and drove it home later and no codes were ever thrown again. Im taking it right now to have the wheels balanced again.
Old Dec 21, 2005 | 10:31 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
DTC C1248 IPC Indicated Low Brake Fluid.
The red BRAKE warning indicator should also be lit.
Old Dec 21, 2005 | 10:33 AM
schtick's Avatar
schtick
Also, that site shows that C1225 is RF excessive wheel speed variation. DIC also showed: service active handling, service ABS, and service TCS. The TCS light and the ABS lights both came on.
Old Dec 21, 2005 | 10:36 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
DTC C1225 is the LEFT FRONT.
Old Dec 21, 2005 | 10:40 AM
sweetcharity
Here is a decent link for you......OBD II Codes
Old Dec 21, 2005 | 05:26 PM
schtick's Avatar
schtick
Thanks guys. Nothing else has come of it so far. I got my wheels balanced again and everything has been fine.
To What DIC Code Is This???
