Battery Insulator
Old Dec 21, 2005 | 11:03 AM
jrut's Avatar
jrut
Default Battery Insulator
I recently replaced my leaking Delco battery with an Optima. When I installed it I did not even try and replace the foam insulator cover. Any harm in that ? What is the purpose of that insulator anyway ?
Old Dec 21, 2005 | 12:17 PM
BadAV's Avatar
BadAV
It's supposed to help shield the battery from the under-hood heat.
Old Dec 21, 2005 | 07:26 PM
jrut's Avatar
jrut
Any problem with running an Optima without it ?
Old Dec 21, 2005 | 07:30 PM
jimmie jam's Avatar
jimmie jam
no. they would supply you with one if it was necessary. if you have one you can use it if you like.
Old Dec 21, 2005 | 10:03 PM
LoneStarFRC's Avatar
LoneStarFRC
No. I agree with the others; if you have one or can cut it to fit, fine. If not no problem. HTH
Old Dec 22, 2005 | 06:32 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is just for shielding and insulation. I replaced my OEM battery with and Optima red two years ago and did not put the insulator back in. Its been fine.
Paul
Old Dec 22, 2005 | 08:03 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Paul
Same here. I replaced mine with an Optima and ditched the insulation. No problem thus far.
No problem with leaving the insulator off.
To Battery Insulator
