Thermostat O-Ring Gasket
Old Dec 23, 2005 | 07:46 PM
CSTYLEZ's Avatar
CSTYLEZ
Default Thermostat O-Ring Gasket
Does anyone know if the rubber O-ring gasket can be purchased seperatley and where? I just got my water pump and T-Stat housing back from the chrome shop and they didnt send back the gasket.
Old Dec 23, 2005 | 07:58 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I thought it was part of the housing as it is not listed seperate
http://www.trademotion.com/partlocat...04&catalogid=1
Old Dec 23, 2005 | 09:16 PM
CSTYLEZ's Avatar
CSTYLEZ
I am not sure if the stock gasket is the rubber O-Ring. My thermostat was replaced when the super charger was installed. I think when you buy the 160 degree thermostat they give you a new housing. I will be sure to call the shop that did the work on Monday if they are open and they can send me a new gasket.
Old Dec 24, 2005 | 04:54 AM
pewter99's Avatar
pewter99
Hmmm..I can't recall.....when my SC was installed I didn't see a used stat in my box of parts but then again I had an aftermarket stat already installed...not a 160 but still.
Good luck man....I hate when you get stuff back and it's incomplete
Old Dec 24, 2005 | 05:36 AM
edensknight's Avatar
edensknight
Yes, the new Thermo comes with a new gasket.
Old Dec 24, 2005 | 11:38 AM
CSTYLEZ's Avatar
CSTYLEZ
Just went to Autozone and ordered the O-Ring. Felpro makes one for 99 cents.
To Thermostat O-Ring Gasket
