Window no worky
Could be a number of things, if there's other issues also related.
Chris
Good luck.
I tried the door slamming and no worky.....
Sounds like relay is clicking up or down.... but no motor worky.
I'll tear apart the psgr door panel tomorrow.
Fun with cars.......
Jeff
The entire unit can cost well over $325. Unfortunately, the power motors are not available separately. Now, provided your door panel switch, AND, your power window modulator are not faulty (do a diagnostics and check for codes), the lack of function is caused by the power window motor jamming. Of course, you can certainly call any of the supporting vendors (Fichtner, Beans, etc.), and, purchase a brand new replacement assembly unit. However, you would save yourself some money by calling up Gene at the Karshop to purchase a used power window motor assembly unit.
Lastly, it sounds as if your modulator and switch are working, BUT, the motor is jamming. Therefore, try hitting the area of the door handle (power motor lies just beneath this area) with several sharp blows. The concussive impact should dislodge the power window motor. Frankly, I find that this method works better than holding the power window motor button down while slamming the door. Do realize that this is merely a temporary fix. And, you may eventually have to replace the power window motor assembly unit down along the line. Good luck.
