Vehicle Build sheet, from GM VIS
Old Dec 26, 2005 | 08:50 PM
djengr's Avatar
djengr
Default Vehicle Build sheet, from GM VIS
Just started to look to replace my wrecked/totaled 98.
Would some one with access to the VIS be kind to run a Vehicle Build Sheet on a 2001 for me.
I have the Summary already, just left the dealer and forgot to ask for the build sheet info.
1G1YY22G115113874
Thanks in advance.
Old Dec 26, 2005 | 09:54 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
1G1YY22G115113874
Thanks in advance.
VEHICLE BUILD
Merchandising Model : 1YY07 -2001 CORVETTE COUPE
Gross Vehicle Weight Rating : 1670 kg (3682 lb) Order Number : CTQQ13
Build Date : 11/16/2000 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CF7 - REMOVABLE SUN ROOF
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE LOW EMISSION VEHICLE G90 - REAR AXLE-3.15 RATIO
G92 - 3.15 PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AY - STOCK ORDERS PROC OPTION
1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 79U - MILLENNIUM YELLOW W/TINT COAT
Old Dec 26, 2005 | 10:21 PM
mikeL82's Avatar
mikeL82
Sponge Vette, will you do the build sheet for me please?
1G1YY32G8X5104099
Mike
Old Dec 26, 2005 | 10:31 PM
Sponge Vette
1G1YY32G8X5104099
Mike
VEHICLE INFORMATION
Merchandising Model : 1YY67 Warranty Start Date : 09/09/1998
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : BOB SMITH AUTOMOTIVE GROUP, INC.
7677 OCEAN GATEWAY
EASTON , MD 21601-8621
(410) 822-1010
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/23/2002 131566 B N0110 - BATTERY - ONE - REPLACE 5582 miles
08/20/2001 121159 # N0110 - BATTERY - ONE - REPLACE 5448 miles
08/20/2001 121159 J V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 5448 miles
08/20/2001 121159 J V0743 - ECL RELAY HARNESS REPLACE 5448 miles
11/06/2000 047411 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 4755 miles
08/31/1998 A04099 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1681 kg (3707 lb)
Order Number : 487US4
Build Date : 08/27/1998 Build Plant : 1X5Y -
BOWLING GREEN
OPTION CODES
AG2 AK5
AQ9 BGR
B34 C05
C60 DL5
DL8 FE1
GU2 IL3
JL9 K63
LS1 MX0
M30 NB6
NG1 NK4
QD4 R9U
R9Z T96
UN0 UZ6
U52 U75
VL7 V73
XGG YGH
1AZ 1SA
16T 70U
94I 943
For some reason the 99 Vettes only come up with codes only. To see what the code above mean click HERE, hope this helps.
Old Dec 26, 2005 | 10:34 PM
edensknight's Avatar
edensknight
Awesome. Spongey to the rescue!
Old Dec 26, 2005 | 10:42 PM
mikeL82's Avatar
mikeL82
Thank you Sponge Vette.
Old Dec 26, 2005 | 11:32 PM
big gil's Avatar
big gil
sponge vette, hate to jump on the band wagon but could you please ran a build sheet for me also. the vin is 1G1YY32G8X5108038. thank you.
Old Dec 26, 2005 | 11:33 PM
deercula's Avatar
deercula
Sponge is DA-MAN, again!
Old Dec 27, 2005 | 07:49 AM
djengr's Avatar
djengr
Thanks Mr. SpongeVette. That's twice you have helped me out, anytime in Edmond OK stop by for a Beer or beverage of your choice.
Old Dec 27, 2005 | 09:15 AM
sprk33's Avatar
sprk33
2018 Grand Sport
SPONGE Could you help me out also dude....Could you run all the info on my car? Here is my VIN: 1G1YY22G715133014. I appreciate it.
Joe
Old Dec 27, 2005 | 04:48 PM
Sponge Vette
Joe
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2001 CORVETTE COUPE Warranty Start Date : 07/11/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : HUDIBURG CHEVROLET, LTD.
7769 GRAPEVINE HWY
NORTH RICHLAND HILLS , TX 76180-7199
(817) 498-2400
CLAIM HISTORY
09/12/2005 552179 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 50621 miles
02/03/2004 517207 # N0110 - BATTERY - ONE - REPLACE 28002 miles
06/18/2003 504436 # J4100 - GENERATOR ASSEMBLY - REPLACE 19499 miles
05/31/2001 A33014 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1669 kg (3680 lb) Order Number : DJBVCH
Build Date : 05/31/2001 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
CF7 - REMOVABLE SUN ROOF CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE LOW EMISSION VEHICLE
G90 - REAR AXLE-3.15 RATIO G92 - 3.15 PERFORMANCE AXLE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL4 - ACTIVE HANDLING SYSTEM
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL SLM - STOCK ORDERS
193 - BLACK LEATHER TRIM SEATING 40U - SPEEDWAY WHITE
Old Dec 27, 2005 | 07:57 PM
RoadReady's Avatar
RoadReady
Sponge Vette, would you please run one on 1G1YY22G525123180. It went into service on 3.9.02, but I would like to know the "born on" date.
Thanks in advance,
Jim
Old Dec 27, 2005 | 08:01 PM
sprk33's Avatar
sprk33
2018 Grand Sport
Default thks
Thanks a bunch Sponge...U the man...
Old Dec 27, 2005 | 09:15 PM
Sponge Vette
Thanks in advance,
Jim
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE Warranty Start Date : 03/09/2002
Delivering Dealer : GWATNEY CHEVROLET-OLDSMOBILE-ISUZU, INC.
2000 COVINGTON PIKE
MEMPHIS , TN 38128-6982
(901) 387-2000
CLAIM HISTORY
08/01/2005 155496 0 J4100 - GENERATOR ASSEMBLY - REPLACE 22748 miles
02/11/2005 152901 # F9995 - CUSTOMER CONCERN NOT DUPLICATED 17252 miles
02/11/2005 152901 # R0760 - RECEIVER, RADIO - REMOVE, REPAIR, AND REPLACE 17252 miles
12/27/2004 152064 # N3230 - ACTUATOR ASSEMBLY - HEADLAMP - RIGHT - REPLACE 17046 miles
12/27/2004 152064 # N4829 - MODULE - HEADLAMP CLOSURE PANEL - REPLACE 17046 miles
03/19/2003 110836 # N0110 - BATTERY - ONE - REPLACE 9595 miles
03/19/2003 110836 # R0760 - RECEIVER, RADIO - REMOVE, REPAIR, AND REPLACE 9595 miles
07/29/2002 100654 # D3200 - TUBE, EXPANSION (ORIFICE) - REPLACE 6430 miles
02/27/2002 A23180 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1682 kg (3709 lb) Order Number : DWPBTK
Build Date : 02/27/2002 Build Plant : 125Y
OPTION CODES
BGR - BOWLING GREEN PLANT CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - DUAL REMOVABLE ROOF PANELS DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
FE9 - 50-STATE LOW EMISSION VEHICLE GU2 - REAR AXLE 2.73 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - COMPACT 12 DISC CHANGER, REMOTE
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
67I - LIGHT OAK INTERIOR TRIM 673 - LT OAK LEATHER TRIM SEATING
70U - TORCH RED
How was that Mr. THOMPSON
Old Dec 27, 2005 | 10:47 PM
big gil's Avatar
big gil
thanks very much, your post gave me a wealth of infor, again thanks sponge vette, you are one of a kind!
Old Dec 27, 2005 | 11:18 PM
dataporter's Avatar
dataporter
Would you please run this one?
1G1YY12G1X5110749
Thanks in advance!
Old Dec 28, 2005 | 08:22 AM
Sponge Vette
1G1YY12G1X5110749
Thanks in advance!
VEHICLE INFORMATION
Merchandising Model : 1YY37 Warranty Start Date : 11/30/1998
Delivering Dealer : LES STANFORD CHEVROLET, INC.
21711 NEWMAN AVENUE
DEARBORN , MI 48123-2200
(313) 565-6000
Open Recall Notice:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004
CLAIM HISTORY
01/08/2002 067265 # J4100 - GENERATOR ASSEMBLY - REPLACE 27045 miles
01/08/2002 067265 # N0110 - BATTERY - ONE - REPLACE 27045 miles
01/08/2002 067265 # V0743 - ECL RELAY HARNESS REPLACE 27045 miles
06/12/2001 059088 # C6501 - HANDLE, FRONT SEAT BACK ACTUATOR (RECLINING OR RELEASE UNI 25308 miles
06/12/2001 059088 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 25308 miles
05/25/2001 058435 # C9041 - BELT, SEATBELT RETRACTOR (FRONT) (LEFT) - REPLACE 24908 miles
05/25/2001 058435 # B1390 - PANEL, HEADLAMP CLOSURE - ALIGN 24908 miles
01/19/2001 053402 # C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 22587 miles
01/19/2001 053402 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 22587 miles
12/11/2000 051906 # B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 22169 miles
06/06/2000 043032 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 17953 miles
02/23/1999 262188 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 3162 miles
10/29/1998 A10749 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1637 kg (3610 lb) Order Number : 915D6C
Build Date : 10/28/1998 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AK5 AR9
BGR B34
C60 DL5
DL8 FE3
FE9 GU6
IP3 JL9
K63 LS1
MM6 MN6
NF2 NK4
NV7 QD4
UL0 UQ5
U52 U73
VM3 V73
XGG YGH
Z19 Z51
1AY 1SA
19I 193
70U
To see a list of option above click HERE
To Vehicle Build sheet, from GM VIS
Old Dec 28, 2005 | 10:05 AM
RoadReady's Avatar
RoadReady
That was great! Thanks a bunch!!!
FYI, the two 2.11.05 radio service entries was the dealership tech recovering the theft code entered when the radio was replaced...and the code he recovered was incorrect.... I went through the Forum procedure and reset the code. The Forum is a great place because of guys like you, buddy!
Old Dec 28, 2005 | 12:25 PM
dataporter's Avatar
dataporter
Old Dec 28, 2005 | 01:18 PM
Tony2's Avatar
Tony2
Sponge,
If you dont mind would you do one for me as well?
vin #: 1G1YY32G025133279
I really appreciate it and thanks in advance,
Tony
