ERR message on CD player!! HELP!!
Old Dec 27, 2005 | 04:09 AM
97C5driver's Avatar
97C5driver
Default ERR message on CD player!! HELP!!
This used to happen every so often, my stock bose cd player would spit out my cds for about 10 minutes and then finally it would read them.
But the other day it started and didnt stop. Every time I put a cd in, it gets spit back out with the ERR message on the radio.
I bought a cd lens cleaner and used it.then the cd player worked. then the next day, ERR. sometimes if im lucky i can get it to play a cd.
what else can i do besides getting a new deck installed? are there any other options besides the cd lens cleaner to clean the deck?
thanks.
Old Dec 27, 2005 | 06:27 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
are these store bought or self made?
some of the self made discs won't work
Old Dec 27, 2005 | 09:10 AM
JetJazz's Avatar
JetJazz
The single CD player in my 2000 does the same thing. Spits them right out. The 12 disc changer works great.
JetJass
Old Dec 27, 2005 | 10:11 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Are these original CDs or copies/burns?
Old Dec 27, 2005 | 05:02 PM
97C5driver's Avatar
97C5driver
its both types of cds.
when it worked , it would play every burned cd i put into it. but its def. something beyond cd type because i can put a brand new real cd in it and it will do the same thing.
i wish i had the money for a new deck so i could pull the bose out and smash it into a hundred pieces.
Old Dec 27, 2005 | 05:58 PM
screw991le's Avatar
screw991le
You can get a new deck for around $100 rom ebay or Gene@karshop
Old Dec 27, 2005 | 07:19 PM
edensknight's Avatar
edensknight
Old Dec 27, 2005 | 07:40 PM
97C5driver's Avatar
97C5driver
i know i own a c5, but im 21 and broke. $100 is completely out of my budget right now. i hate bills.
anyway, i guess im just stuck with my problem for right now since there doesnt seem to be any other type of cleaning solutions.
Old Dec 27, 2005 | 09:40 PM
Vince2001's Avatar
Vince2001
4th Gear
Default Hope this might be of some help
When the refection of the pits and landings on the bottom (shiney side) of the CD is not being detected/read a error mesage will appear. The following can cause this problem, electronic breakdown, mechanical failure or dirt. Electronic and mechanical failure usualy reguire a skilled technician. Cleaning can be accomplished with a CD cleaning kit, canned clean compressed air or if you have the unit open a sponge swab with isopropal alcohol applied carefully. To test use a original audio CD that works on other players. Be careful and Good LUCK
Old Dec 29, 2005 | 03:11 PM
vcarr's Avatar
vcarr
I hate to tell you this but this is normal for these stock radios.I had the same problem with the one in my silverado (same stereo).Everything worked fine except when it came down to the cd player.It did the same thing as yours.Cleaned it and worked on and off.Since the truck had warranty I took it to the dealer and they don't fix this,they replace it.Again it worked like it should for the next 2 years.Then it did it again.By then the warranty had expired so I bought one in a junk yard and it worked fine for about 4 months and then did the same thing.Finally gave up and went aftermarket.When I bought my vette it had the same problem so I got another factory stereo and put it in.Needless to say it started to do the same thing.So I can say that I have gone through 5 of these and all with the same problem.There was a recall on these @ one point I was told by the dealer but only for a certain year.
Old Dec 29, 2005 | 03:49 PM
97C5driver's Avatar
97C5driver
yeah i figured that im just going to have to get an aftermarket stereo to cure this. i guess i'll just listen to my exhaust for a couple of months.
a buddy of mine has a 04 tahoe and his radio does the same thing. damn i sure do love chevy.
To ERR message on CD player!! HELP!!
