High Pitch
Old Dec 28, 2005 | 10:26 AM
comtrans's Avatar
comtrans
7th Gear
Default High Pitch
After 59 years I finally got the car that I have always wanted, a 1997 with 32000 miles. I have read the forum every day for a couple of months now and learned more than I could have hoped to but now have a question that I have not seen posted.
I have a high pitch hum or tone coming from the back of the car. Turning the radio off does no good. A very uneducated guess on my part would be a fuel pump but, obviously, it is just a guess. Can anyone help me with this?
In advance, thanks for your help. This is a great bunch of Corvette owners from what I have see so far.
Old Dec 28, 2005 | 10:31 AM
97Black's Avatar
97Black
If it is coming from behind you on driver side then yes it is the fuel pump. After the car warms up it usually is not noticeable. I believe there is a way to insulate that area to cut down on the noise but I have not done it.
Old Dec 28, 2005 | 10:39 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Too bad it's not from the front cause then I'd say it was the supercharger you didn't know you had.
From the rear I'd say fuel pump. If it stops when the car is stopped then I'm guess rear end or tranny. Just my .02!
Old Dec 28, 2005 | 11:05 AM
comtrans's Avatar
comtrans
7th Gear
Thank you very much for your information. (No, I didn't know I had a supercharger, by the way!!!)
Can I access the pump from the interior?
Old Dec 28, 2005 | 12:17 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As others have indicated I'd say you are spot on with your fuel pump guess. The '97's had a known issue with noisy fuel pumps. My '97 has had this since I got her four years ago. I've put about 30,000 miles on the car in this time. It is not symptomatic of a pending failure and for the most part is just an annoyance. I've heard it is about 700 dollars to repair. I don't know if this is true or not.
Paul
Old Dec 28, 2005 | 12:52 PM
Humy's Avatar
Humy
I like it, it sounds like a noise a fighter jet makes on the runway
Old Dec 28, 2005 | 12:56 PM
Crispyc21's Avatar
Crispyc21
I have the same noise on my 97...it's the fuel pump. Once I get moving I don't hear it because either the radio or my Corsas. That's the cheapest fix.
Old Dec 28, 2005 | 03:13 PM
edensknight's Avatar
edensknight
Paul
Yes, they are loud on the '97's. However, do a diagnostics manual check to be safe, and, to make sure you are not coding for a faulty fuel pump assembly unit.
Old Dec 28, 2005 | 06:39 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
If it's really $700 to fix just spend that on a new exhaust and you'll enjoy it more than putting the $$ into a fuel pump fix. Buy Borlas and I'll bet you never hear the sound again.
Old Dec 28, 2005 | 06:48 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Nope, it is in the tank
Old Dec 28, 2005 | 10:15 PM
PGann's Avatar
PGann
There are actually 2 fuel pumps, 1 in each tank. One pumps fuel from one tank to the other, the other one pumps it to the engine. If you look under the back of your car, you'll see the tanks on either side of the transmission. The pump assemblies are at the back of each tank at the bottom... looking right at you. One will have 2 hoses, the other has 3. As stated, the sound is a known issue addressed on later models. It is not supposed to be an indicator of eminent failure, as often is the case on many other GM vehicles.
To High Pitch
