Is there a thread explaining the different C5 models?
Old Jan 1, 2006 | 10:30 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Originally Posted by Blck00Vette
But the FE3 doesn't mean it has the Z51. This must be two different options..??
Re-read post #15
Old Jan 1, 2006 | 10:35 PM
Z-07 freak's Avatar
Z-07 freak
Originally Posted by Sorny
As has been said above, all '99 & '00 FRC's have the Z51 suspension.
You should see Z19, FE3, Z51, MN6, and a few other things on that card on the glove box lid if you've got a hardtop.
This is true for the `99 FRCs.
But every `00 FRC I've seen does not have Z19 or Z51 listed on the RPO sticker.
Old Jan 2, 2006 | 11:06 AM
EB-Z06's Avatar
EB-Z06
This is why I asked.. I didn't see Z51, but I did see the FE3..
Old Jan 2, 2006 | 11:42 AM
JustinSwinton's Avatar
JustinSwinton
Originally Posted by Togo
the switch on the console is related to ACTIVE HANDLING - this is NOT to be confused with the Z51 suspension - the Z51 suspension is special shocks/sway bars - i want to guess that the Z51 cars probably came with and without A/H
While the button on the center console is for the active handling, make sure not to confuse the adjustable suspension package corvettes that have the dial in which you can configure which suspension setting you wish to use! If you hvae the Z51 you will not have this dial in the car
Justin
Old Jan 3, 2006 | 10:49 AM
Sorny's Avatar
Sorny
Must have been a mid-year change. Mine has both...
Sorny
