Vibration??? Ideas
Old Dec 28, 2005 | 03:18 PM
viperZ06's Avatar
viperZ06
Default Vibration??? Ideas
cruising in 6th between 55 and 70 plus I get a pulsing vibration that comes and goes every few seconds. You can feel it in the drivers seat. It is more pernounced because when it happens I have a rattle in my dash that picks up on it. I am hoping tire balance but can't help but think about the rear end being out of it a few months ago to fix a seal. The guy that did the seal work is top notch so I am back to balancing but can't figure why that would change all of a sudden. Ideas???
Old Dec 28, 2005 | 03:28 PM
RTSVET's Avatar
RTSVET
Sounds like tires are out of balance check your wheels and see if a wheel weight has come off and get them balanced.
Old Dec 28, 2005 | 03:31 PM
NSTG8R's Avatar
NSTG8R
what he said
Old Dec 28, 2005 | 03:55 PM
edensknight's Avatar
edensknight
Well, I am going to agree on this one, too! Check the ballance on all wheels, especially the fronts. Good luck to you.
Old Dec 28, 2005 | 07:10 PM
Hammie's Avatar
Hammie
Start easy, go harder. Check:
Tire Pressure, uniform throughout?
Balancing, locate a HunterGSP9700, go to www.gsp9700.com and locate a gsp9700, so you can find shops that use it. It's a road force testing machine, will pinpoint your vibration cause if it's in wheel or tire.
Alignment
Best of luck.
Old Dec 28, 2005 | 09:14 PM
Z0SLIK's Avatar
Z0SLIK
Alignment
Best of luck.
Old Dec 28, 2005 | 09:18 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Old Dec 28, 2005 | 10:14 PM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
Alignment
Best of luck.
Excellent suggestion!
Old Dec 28, 2005 | 10:42 PM
troy144's Avatar
troy144
To Vibration??? Ideas
