Mass air sensor
Old Dec 28, 2005 | 10:22 PM
Gary French's Avatar
Gary French
Default Mass air sensor
I just put a vararam in my 2003 vert and it works great. Would a Granitelli mass air sensor help and if so how much ? What about a new throttle body and what do you recommend ?
Old Dec 28, 2005 | 10:25 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
What else do you plan on doing with the car? Personally, and I am sure others will post on this, I wouldn't buy a new MAF and I have been told that upgrading a throttle body is a waste of money for the little hp you get unless you do some seriously modding. Get some used headers.
Old Dec 28, 2005 | 10:44 PM
IVOZO6's Avatar
IVOZO6
When you do intake you should do exhaust IE headers, high flow cats and cat back
Then tune.
Will make a world of difference.
Old Dec 29, 2005 | 04:08 AM
SLPRC5's Avatar
SLPRC5
Don't waste your money..put it towards headers, hi-flo cats, X-pipe, cat aft exhaust.
Good luck
Rsty
Old Dec 29, 2005 | 05:04 AM
Shane_S's Avatar
Shane_S
Get yourself some headers and a Tune. A tune will accomplish exactly the same thing as an aftermarket MAF sensor will. Which is. Cars generally run a bit rich from the factory, the aftermarket sensors send a slightly off reading so your car leans out the mix a tad bit. Which will make a little more power. All that can be done in tuning as well as many additional things.
For a $~1000 set of headers and a tune you could gain quite a bit. I got the LG Pro Street headers, Haltech Stinger intake, and a tune and netted over 30rwhp and 25rwtq on an otherwise completely stock ~100k mile LS1
Money well spent there.
Shane
Old Dec 29, 2005 | 06:07 AM
I wouldn't mess with the mass air sensor - the headers and high flow cats sounds like a much better expenditure of money.
Old Dec 29, 2005 | 09:31 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Good luck
Rsty
Old Dec 29, 2005 | 10:03 AM
Joe's Eray's Avatar
Joe's Eray
Old Dec 29, 2005 | 06:34 PM
edensknight's Avatar
edensknight
Good luck
Rsty
To Mass air sensor
