Another Air Intake Thread
I want the most HP bang for the buck and that's why I am thinking Vararam. However, I like the look of the Stinger or Blackwing which would be second choices.
Is there that big of a difference in performance or are they all close enough that my decision should be based on which look I prefer? I don't drag race but I still want top perfromance.
I can get the Vararam for $298 delivered the next 2 days but would not mind spending extra $$ for looks if the performance is close.
I guess I am looking for more opinions because I just can’t make up my mind………
From the MA website.......
"Take advantage of the larger opening on GM's stock 2002 Z06 air cleaner cover and a K&N Air Filter for a dramatic increase in airflow to your 1997-04 Corvette's engine. Keep your original cover for future restoration, while you pump up your C5's power and performance. 612572 kit includes stock 2002 Z06 air cleaner lid, K&N air filter, filter oil and cleaner & degreaser. Easy installation"
I will probably go with the Vararam.
There was a guy a few weeks ago posting on here that with his Automatic 3.15 gears, vararam and borla stinger mufflers ran a 12.6-12.7 just because it was 49 degrees out........(that's only two little mods that aren't really anything to brag about running way into the 12's just because of much colder air with his vararam)
I upgraded my 2004 coupe with 2.73 gears to the Z06 airbox cover, K&N filter, and WCC cold air screens. There was a noticable SOTP improvement in that it is now very easy to set of the traction control at a light. For the most part, these are all stock parts so it is not very radical, but I am happy.
Right on!
of HP I'd obtain with a new intake. So I chose the vararam after doing my
homework. Overall, I'm very happy with it. It delivers increased performance
as promised. The quality was disappointing however. I understand the
quality is better now but I have to use silican sealant to get a good seal
around the filter in the filter housing! Plus the install is probably the most
difficult of any after-market intake... But, if you like working around and
learning about your Vette then you'll enjoy it! Oh, and if your thinking
about upgrading your fog lights, its perfect time to do it!
Good luck with your decission!
