Can I have a G90 and G92 Axle?!
I've just taken delivery of a new (to me) vette, a '99. Having checked in the glovebox for the codes the lable is a little worn. Between FE9 and IL3 there are two codes which I think to be 'G's. I think the first one is G?0, looks like G90, the second one is not very clear but looks like G92. I presume not GU2 as that would be two ratios but what does a 3.15 ratio with performance actually mean?
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
I picked up these codes and assume them to be right.
Received 1,407 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
Yes
You CAN have G90 & G92 together, as a matter of fact whenever G92 is selected as an option, G90 will then also be designated as the actual axle in the car.
You can NOT have G92 and GU6 together.
Your car is obviously an A4
The GU2 is the standard rear and the G90 is the optional "performance" 3.15:1 rear, thus the G92 Performance option designation.
Originally Posted by GOZ2FST
So what's the difference between a G90 and a G92?
G90 actually tells WHAT optional rear was put into he car, G90 = 3.15
Cruise-In II Veteran
Originally Posted by Glennm27
G92 just states that the car was ordered with an optional rear oppossed to the standard 2.73.
1 Post
1 Post
