Cam Thoughts
Old Jan 1, 2006 | 07:38 PM
freemanjc's Avatar
freemanjc
Default Cam Thoughts
Is there anyone here that can give me thoughts on this CAM
(Comp Cam 220-224 on a 114 +1)
I will be running these with stock heads, Shorty BBK Header, Varaam, Borl Quad Stinger and a DYNO Tune with EFI Live. Charlie at A&A e-mailed me and told it was perfect with the stock heads and told me in his own words
(QUOTE)
(Stay with the shorty headers. They are a good combination with the cam you have chosen (good choice)!
(END QUOTE)
So, I was wondering if anyone had one installed or if anyone could estimate after the complete install where I will finish on the dyno! I do not want to be in the excessive 400+hp crew, I just want to get to around 380HP! Also, should I change my intake as well, and if so too which one!
Thaks guys!
Free
Old Jan 1, 2006 | 07:40 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
(QUOTE)
(END QUOTE)
Thaks guys!
Free
You will NOT get to 380rwhp with those mods - but I do not want to second guess Charlie - A&A know their stuff.
Old Jan 1, 2006 | 08:00 PM
freemanjc's Avatar
freemanjc
I know I will not get there with those changes, that is my ultimate goal though! However I was tld I should be in the 348+ range give or take!
Old Jan 1, 2006 | 08:09 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
So, why not go with a slightly larger cam? Not a massive LG cam or anything but maybe a 228/232, or a 232/236 range?
Chris
Old Jan 2, 2006 | 04:38 PM
freemanjc's Avatar
freemanjc
Chris
Chirs
Becuase I do noknow what I am doing! That Why I am in here asking opinions. I think i should be buying a H/C kit vice just heads and cam..Correct?
Old Jan 2, 2006 | 06:17 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Chris
Go with LG's original G5 cam with a 114 lsa will work great.jerry
Old Jan 2, 2006 | 06:24 PM
Stangkiller
Chirs
So now you want Heads AND a Cam? Not just a Cam? Buying a cam kit, you can sometimes save money, but other times the dealer will just find ways to slip products you don't need into the kit, so watch waht you're buying.
For a cam install you need, the front timing chain cover gasket, Cam, Springs, Retainers, Hardend push rods, and a new balancer bolt.
For head swap, you'll need a few more gaskets.
Chris
Old Jan 2, 2006 | 06:25 PM
Stangkiller
Not bashing the LG cams, just seemed like he was looking for something a bit less aggressive.
To Cam Thoughts
