Is a tune worth it?
This sounds like a winning formula to me.
C'mon, EG. With all the work you have done on Grond, you should know this. The speed sensors in the hubs are for ABS/TC/AH. The speed sensor (VSS) for the speedo is mounted on the differential and reads off the output side, hence no speedo adjustments on C5s. See Mike Mercury's page for more info.
A lovely tune would do me good...
Thanks!!!~~~JadeDragon
It's also good to see how much knock retard your engine might be getting too, so that you can set up your spark advance curve to eliminate that. And the air/fuel ratio from the factory is never perfect either. Smoothing that out makes the engine much smoother at full throttle. I've had my car tuned twice, once when bone stock and again last week when I had the Vararam installed. I didn't even need to pay extra for the re tuning, they did that for me for free!
. The car was totally different. See sig.Here is the dyno sheet.
What exactly is involved in a tune?
Every tuner has his own idea of what is an ideal air/fuel ratio, but I believe most of them shoot for around 13.0 to 1 at WOT on a normally aspirated car. (they'll want it richer for forced induction or nitrous) The amount of timing they put in the car will depend on the octane of the fuel you're using, and the level of mods you're running. Most tuners will end up finding that the car has a bit of knock retard with the stock timing curve, so they'll end up taking out a little bit of timing until they see the scan tool show no knock retard on it.
In most cases it will take about 5 dyno pulls to get the proper tune. A good tuner will also know how to set up the part throttle parameters so that the engine feels much more responsive in normal driving too. A good tuner will also know how to tune not only for the best peak hp, but for most average horsepower overall, in other words he'll want to see a good powerband overall, with a nice flat torque curve. Peak horsepower is not the only way to gain performance, you can gain a lot by concentrating on tuning the engine in the midrange too.
With an automatic car, they can also adjust your shift points, and speed up the time it makes the shift too. They can eliminate the torque management (which retards the timing on the shifts to soften the strain on the trans, but also slows down the car) They can also play with the torque converter lock up points too. And one thing I found out on my last tuning session is that they can adjust the refresh rate for the knock sensors, so that if the engine senses knock but then the knock goes away, the computer will put the timing back in faster. There are also other things they can adjust in the tuning session too such as the rev limit (if you're running better heads and cam you'll want the engine to be able to rev past the stock limit)
With the right person doing the tuning, it is a wonderful thing!
Ken
