Which CLB
Old Jan 2, 2006 | 01:08 PM
stevez's Avatar
stevez
Default Which CLB
Does anyone know if there is a difference in the column lock bypass kits sold by various vendors??
I have the service column lock message and it is time to get the bypass. Luckily car is in garage for the Ohio winter.
Old Jan 2, 2006 | 01:09 PM
Don't know if there is much difference in the kits, but I got mine from Thunder Racing. Easy to install and works perfect. Corvettes of Houston also sells the kit and have heard good things about them.
Old Jan 2, 2006 | 01:13 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
I got mine from Corvettes of Houston. So far, no problems!
DBL001's Avatar
DBL001
Got mine from Corvettes of Houston, fast and easy transaction, easy to install, problem solved
Old Jan 2, 2006 | 03:19 PM
JohnnyB's Avatar
JohnnyB
Thunderracing.com
Weren't they the originals?
Old Jan 2, 2006 | 03:22 PM
TOPGUN9's Avatar
TOPGUN9
If your column is locked, you have to get it unlocked before installing the CLB. Just an FYI.
Old Jan 2, 2006 | 04:07 PM
steve8's Avatar
steve8
Same here.
Old Jan 2, 2006 | 05:18 PM
gordonb50's Avatar
gordonb50
Old Jan 2, 2006 | 06:50 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Thunder racing here and no problems.
Old Jan 2, 2006 | 08:08 PM
Tigershark3's Avatar
Tigershark3
Got mine from Corvettes of Houston. Just installed it today. Hardest part was fitting the bottom panel again - could not get the holes to line up for the screws. Plus I found some bad wiring from a previous owner's stereo install I had to repair before I buttoned it up.
It would have been tougher without the sticky - the instructions that came with the bypass were ok but the sticky and the referenced links are what really got me through it.
Old Jan 2, 2006 | 08:12 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09
I have not installed it yet, but anticipate no problems.
Old Jan 2, 2006 | 08:13 PM
troy144's Avatar
troy144
I have a 2001 vette. What are the odds that I am going to be needing this? Is this a certainty over time?? Thanks for any response... Should I keep doing my prayers...
Old Jan 2, 2006 | 09:02 PM
stevez's Avatar
stevez
not locked - jsut the service column lock message
the steering wheel is free
Old Jan 2, 2006 | 10:04 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
Old Jan 2, 2006 | 10:56 PM
rws.1's Avatar
rws.1
My 2001 MN6 Vert had the dealer recall performed twice.... by the previous owner.
Within the first week I had the DIC service column lock message.
I ordered the COH CLB... before it arrived the column locked, but thanks to the sticky ... I was able to unlock it.
The day the CLB arrived I installed it..... problem free since then.
Old Jan 3, 2006 | 12:31 AM
WWK888's Avatar
WWK888
Why risk getting stranded? Just install it and be safe.
Old Jan 3, 2006 | 12:47 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
There is no time/mileage number for the column to lock up. My '98 had 18K on it when it decided to crap out. Spend the fifty bucks, give yourself an hour and a beer (or lemonade) and you'll be worry free!
To Which CLB
