just thought you should know
Old Jan 5, 2006 | 10:40 PM
fas01's Avatar
fas01
Cruising
Default just thought you should know
I recently read here on the forum about autoasscessoriesstore.com having thinner brushed aluminum dash trim parts. So I checked it out, read all about their processes and ordered a set. I get it and its as advertised .010 thick but that included the .004 backing paper thickness. No problem I'll send it back, which is a bit of a process, but then I find out a 20% restocking charge is assessed. It seems to me that's how they make there money for this junk, because as it turned out that is exactly what it was, JUNK.
Old Jan 5, 2006 | 11:48 PM
b98's Avatar
b98
thanks for the info.
Old Jan 6, 2006 | 08:18 AM
mikestuff's Avatar
mikestuff
It's early in the morning and I'm probably missing the point entirely, but if you ordered the trim pieces because they are thinner than other vendors, and when you get it, it's .010 including the backing, when you remove the backing, it would be even thinner, wouldn't it? Does it look crappy? Like I said, I'm probably missing something.
Old Jan 6, 2006 | 08:21 AM
Shane_S's Avatar
Shane_S
maybe it would have been acceptable if the aluminum itself were say .008 and the backing .002? I dont get the point either.
Shane
Old Jan 6, 2006 | 08:34 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Are we talking about trim parts that get stuck on with double sided tape?
Old Jan 6, 2006 | 09:45 AM
Bman's Avatar
Bman
St. Jude Donor '05
Maybe you can file a dispute with your credit card company!!
Old Jan 6, 2006 | 09:54 AM
Craig Wagner's Avatar
Craig Wagner
Add me to the "don't get it" list. Is anything less than .010 lousy? Does the .004 make the difference?
Old Jan 6, 2006 | 10:01 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi fas01 -
It would help us understand what you are telling us if you had some pictures of the items that you ordered.
I am going to assume that you received the stick-on dash trim parts and they were not of the quality that you anticipated.
Stuff like that happens all the time, unfortunately.
I do not necessarily agree that sellers should charge exhorbitant "restocking" fees, but that is entirely my opinion.
I am sorry that you got bit on this one - but at least it was only for 20% of the cost of dash stick-on trim parts - you might just have dodged a bullet on that one anyway...
best regards -
mqqn
Old Jan 6, 2006 | 11:20 AM
RENO's Avatar
RENO
OK, so I think I understand
when it comes to crap I want to stick-on
.010 = ultimate cool
.009 = just cool
.008 = not cool, but still OK
.007 = bad
.006 = teh suck
Old Jan 6, 2006 | 02:34 PM
Vetten Vayo's Avatar
Vetten Vayo
Thanks for the heads up.
Old Jan 6, 2006 | 07:08 PM
Not uncommon for some vendors to charge a restocking fee - at least they advertise it that way. Sometimes you can get them to waive the fee if your reason for returning is good. I guess I see your point that one could be led to believe that the aluminum itself was .010" thick.
Old Jan 6, 2006 | 09:38 PM
fas01's Avatar
fas01
Cruising
I also tought that thinner would be better but they were so thin it looked more like a decal than real aluminum the pieces were also poorly cut, and not what they advertised.
Old Jan 6, 2006 | 11:33 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Jan 6, 2006 | 11:58 PM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I recently ...I get it and its as advertised.
...and not what they advertised.
I am really
To just thought you should know
