Head Lights - "Down Boys"
Old Jan 6, 2006 | 07:06 AM
KD-Columbus's Avatar
KD-Columbus
Default Head Lights - "Down Boys"
How do you get the head lights down when the auto sensor wants them up? My 1979 doesn't suffer from this computer controlled affliction....
Old Jan 6, 2006 | 07:16 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Check your owner's manual and you can turn off the auto sensor function using the DIC feature. Should be under "Options".
Old Jan 6, 2006 | 08:22 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Twilight sentinel - off.
Old Jan 6, 2006 | 12:34 PM
JoshVette's Avatar
JoshVette
Go to options, select Twilight option, hit reset.
I didn't like mine doing it either.
BTW, you can reprogram most of the little features with the options button.......
Old Jan 6, 2006 | 12:36 PM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
Ive never had this problem is this on ALL c5s... i have a 97
Old Jan 6, 2006 | 12:51 PM
JoshVette's Avatar
JoshVette
The Twilight Sentanial is an optional feature, some have it some don't depending on the option package your vette came with.
Driving in and out of the parking garage at work made it very annoying and I'm sure it would have worn out the headlight motors even faster.
Old Jan 6, 2006 | 02:41 PM
edensknight's Avatar
edensknight
Old Jan 6, 2006 | 03:14 PM
sebringsilver97coupe's Avatar
plus i think it wasnt available on the early ones but ive been wrong once or twice.
original poster-u should be able to turn them off via DIC unless is canadian and then i think u are stuck w/them....but again...ive been wrong before..
To Head Lights - "Down Boys"
