Strange Vibrations
Old Jan 7, 2006 | 04:40 PM
GKrenn's Avatar
GKrenn
Default Strange Vibrations
Last week I had a rear tire (Non Runflat) patched because of a nail. This is the second patch in the tire and they are about 6 inches apart. I did not get to do any highway driving until this week. The first day I could hear a very light pulsating vibration in the cab at 65mph. I thought maybe the roof latchs or the mirror may have been a little loose but they were not. The next day I could feel it vibrating, now between 60 to 70 mph. I had the tire rebalanced and it is little less noticeable. The tires are near the end of their lifespan. What puzzles me is the pulsating part. At lower speeds and above 70 it seems normal. Anybody else ran into something like this?
Old Jan 7, 2006 | 04:51 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I would get a new tire all together...what tires are you running.
Old Jan 8, 2006 | 10:06 AM
GKrenn's Avatar
GKrenn
Pirelli P zero nero's
Old Jan 8, 2006 | 10:14 AM
Patches's Avatar
Patches
A bad hub bearing can also cause that symptom. You should be able to determine if it's just an out-of-balance, worn tire when you swap in new tires. If the problem persists, check out the bearings.
To Strange Vibrations
